Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
30
Past 30 Days:
139
All Time:
5,214
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Step by step guide for replacing your damaged LCD Display.
Parts
Tools
    1. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 1: step 1, image 1 of 1
      • Remove the battery and memory card from the device.
      Ask FixBot
    2. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 2: step 2, image 1 of 1
      • Remove the single .5mm screw on the left side of the camera.
      Ask FixBot
    3. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 3: step 3, image 1 of 1
      • Remove 4 (0.5mm) screws from the right side of the camera.
      • There are two screws at the top.
      • There are two screws at the bottom.
      Ask FixBot
    4. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 4: step 4, image 1 of 1
      • Remove 5 screws from the base of the camera.
      • There are two (0.2mm) screws next to the battery compartment.
      • There are three (0.5mm) screws around the tripod base mount.
      Ask FixBot
    5. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 5, image 1 of 1
      • Slowly open the back cover away from the device
      • The wrist strap bar can easily be lost so now is a good time to remove it.
      • Use caution. The rear cover is attached to the Main PCB via cables. You will need to release these cables before removing the rear cover.
      Ask FixBot
    6. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 6, image 1 of 2 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 6, image 2 of 2
      • Detach both ribbon cables using a spudger or other method.
      • Lift the black clip upward, unlocking the ribbon cable
      • Once the clip is in the up position you can slide the cable out. Release cable by pulling the cable out.
      • DO NOT pull on the Back case to release the cable.
      Ask FixBot
    7. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 7, image 1 of 1
      • Screw Arrangements
      • Make sure you organize your screws to make re-assembly easier.
      Ask FixBot
    8. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 8: step 8, image 1 of 1
      • Remove the back casing from the camera.
      Ask FixBot
    9. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 9, image 1 of 3 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 9, image 2 of 3 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 9, image 3 of 3
      • Use a spudger or other tool to release the 3 clips between the LCD case and housing.
      • Note: when re-assembly all 3 clips need to be seated in the grooves as shown in the 2nd picture.
      • Lift LCD out as shown in 3rd picture
      Ask FixBot
    10. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: step 10, image 1 of 1
      Ask FixBot
Sales Cameraparts4you
3,492 Reputation
23 Guides authored
3 Guide Comments
Very well presented and helpful - thank you.
It sems important to use the correct screwdriver and my impression is that the screws are JIS rather than Philips.
So far I have been unable to locate a replacement screen with back light (I assume the back light is connected by the narrower ribbon cable).
George Winspur - Reply Share
I  Like my Panasonic  DMC-TZ3  , paid 300 way back in 2007  and has flawlessly  perfect, till I Dropped it in the case  …
IT still take pictures,  store on Memory, etc  all functions work , and can down load to computer ..
BUT the Back LCD  I can barely see unless I put a LIGHT to it ….
SO I assume I screwed the Back Light,  … can anybody help ?
Gary Trembley - Reply Share
Hi…. the backlite cable might have come loose or damaged. I would disassembly the unit and re-insert the backlite cable to see if that does the trick.. Otherwise you would have to invest in a new Display ASSY or backlite. A used backlite or Display assy is not that expensive and easy to replace..
Sales Cameraparts4you - Reply Share
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 139
All Time: 5,214
