Up to 20% off select tools
Panasonic CF-31 Toughbook Keyboard Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
100
All Time:
3,859
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This is a guide for replacing a keyboard on the Panasonic CF-31 Toughbook laptop. The Panasonic CF-31 laptop is a fully rugged laptop designed to operate in environments not suitable for your normal laptop, such as extreme heat and cold, rain, dust, and a drop from a height of six feet or under. These conditions can cause components like the keyboard to malfunction, causing a need to repair or replace the keyboard. This repair guide will outline the steps to replacing the keyboard on the Panasonic CF-31 Laptop, the tools needed, and a list of parts needed to complete the repair.
    1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: step 1, image 1 of 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: step 1, image 2 of 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: step 1, image 3 of 3
      • Open the battery compartment by pulling the tab forward and then down.
      • Open the compartment door by pushing down.
      • Use the plastic tab to pull the battery out of the compartment.
      Ask FixBot
    2. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 2, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
      • Use a nylon spudger to remove the bezel.
      Ask FixBot
    3. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 3, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 3, image 2 of 2
      • Use a nylon spudger to lift each corner of the keyboard.
      • Use your hands and gently pull back to remove the keyboard.
      Ask FixBot
    4. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 4, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 4, image 2 of 2
      • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
      • Remove the keyboard shield.
      Ask FixBot
    5. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 5, image 1 of 1
      • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
      Ask FixBot
    6. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 6, image 1 of 1
      • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
      Ask FixBot
    7. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 7, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 7, image 2 of 2
      • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
      Ask FixBot
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Author
with
Richard Gill
154 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 3,859
