Up to 20% off select tools
PalmOne Zire 72 Camera Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
92
All Time:
1,201
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. PalmOne Zire 72 Camera Replacement, Camera: step 1, image 1 of 2 PalmOne Zire 72 Camera Replacement, Camera: step 1, image 2 of 2
      • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
      Ask FixBot
    2. PalmOne Zire 72 Camera Replacement: step 2, image 1 of 1
      • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
      • If you peel the entire label off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
      • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
      Ask FixBot
    3. PalmOne Zire 72 Camera Replacement: step 3, image 1 of 1
      • Use a #00 Phillips screwdriver to remove the 2.5 mm hidden screw.
      Ask FixBot
    4. PalmOne Zire 72 Camera Replacement: step 4, image 1 of 1
      • Use either end of the spudger to carefully pry off the camera lens mesh cover.
      Ask FixBot
    5. PalmOne Zire 72 Camera Replacement: step 5, image 1 of 1
      • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
      Ask FixBot
    6. PalmOne Zire 72 Camera Replacement: step 6, image 1 of 2 PalmOne Zire 72 Camera Replacement: step 6, image 2 of 2
      • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
      • Gently remove the case to avoid damaging it.
      • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
      Ask FixBot
    7. PalmOne Zire 72 Camera Replacement: step 7, image 1 of 2 PalmOne Zire 72 Camera Replacement: step 7, image 2 of 2
      • Remove the cover by lifting it from right to left.
      • This should be similar to the action of the opening of a book.
      • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
      Ask FixBot
    8. PalmOne Zire 72 Camera Replacement: step 8, image 1 of 1
      • Remove the control pad buttons from the device and set aside.
      Ask FixBot
    9. PalmOne Zire 72 Camera Replacement: step 9, image 1 of 1
      • Wedge the flat end of the spudger underneath the battery and gently pry it out.
      • Be cautious of the red and black wires on the battery, which may rip easily.
      • The battery may have adhesive holding it to the device.
      • Be careful with the battery connector, which may rip.
      Ask FixBot
    10. PalmOne Zire 72 Camera Replacement: step 10, image 1 of 1
      • Gently disconnect the white component connecting the battery to the motherboard.
      • The connector should be pulled upward.
      Ask FixBot
    11. PalmOne Zire 72 Camera Replacement: step 11, image 1 of 1
      • Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
      Ask FixBot
    12. PalmOne Zire 72 Camera Replacement: step 12, image 1 of 2 PalmOne Zire 72 Camera Replacement: step 12, image 2 of 2
      • Unplug the orange video connector leading from the lower case to the upper case.
      • The orange video connector is the cable that connects the motherboard to the screen.
      Ask FixBot
    13. PalmOne Zire 72 Camera Replacement: step 13, image 1 of 3 PalmOne Zire 72 Camera Replacement: step 13, image 2 of 3 PalmOne Zire 72 Camera Replacement: step 13, image 3 of 3
      • Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side.
      • If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
      Ask FixBot
    14. PalmOne Zire 72 Camera Replacement: step 14, image 1 of 1
      • Using the spudger, pry the motherboard off of the device.
      • We recommend removing the motherboard off of the device from left to right.
      Ask FixBot
    15. PalmOne Zire 72 Camera Replacement: step 15, image 1 of 2 PalmOne Zire 72 Camera Replacement: step 15, image 2 of 2
      • Feed the video connector from the camera through the square hole in the motherboard.
      • After doing so, you may carefully lift the motherboard out of the back case.
      Ask FixBot
    16. PalmOne Zire 72 Camera Replacement: step 16, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, pry one side of the clip off.
      Ask FixBot
    17. PalmOne Zire 72 Camera Replacement: step 17, image 1 of 1
      • Now that the camera is loose, you may pick it up and remove it from the case.
      Ask FixBot
Author
with
Michelle Medina
89 Reputation
5 Guides authored
Cal Poly, Team 6-49, Amido Spring 2012 Member of Cal Poly, Team 6-49, Amido Spring 2012
CPSU-AMIDO-S12S6G49
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 92
All Time: 1,201
