Up to 20% off select tools
Palm v Outer Case Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
92
All Time:
2,467
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
How remove the outer casing
    1. Palm v Outer Case Replacement, Outer Case: step 1, image 1 of 1
      • Lay device face down on surface.
      Ask FixBot
    2. Palm v Outer Case Replacement: step 2, image 1 of 2 Palm v Outer Case Replacement: step 2, image 2 of 2
      • Heat the left and top edges with hairdryer for one minute.
      • Move hairdryer back and forth to evenly heat up surface.
      • Caution: directly heating the screen can melt or distort the screen.
      Ask FixBot
    3. Palm v Outer Case Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to hold Palm right side down on it's side.
      • Use a plastic opening tool to pry open front and back casing.
      • If you are unable to open you may need to heat with hairdryer for longer.
      • Be sure not to touch case directly with fingers, it will be hot!
      Ask FixBot
    4. Palm v Outer Case Replacement: step 4, image 1 of 1
      • Leave plastic opening tools in between front and back casing.
      • Rotate Palm and repeat steps 2 and 3 for right and back edges.
      Ask FixBot
    5. Palm v Outer Case Replacement: step 5, image 1 of 3 Palm v Outer Case Replacement: step 5, image 2 of 3 Palm v Outer Case Replacement: step 5, image 3 of 3
      • Now pry open front and back casing with plastic opening tools.
      • Separate front and back casing completely.
      • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
      Ask FixBot
Finish Line
Author
with
Anthony Platt
66 Reputation
3 Guides authored
Cal Poly, Team 13-25, Maness Winter 2010 Member of Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 Members
48 Guides authored
1 Guide Comment
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 92
All Time: 2,467
