Up to 20% off select tools
Palm m500 Back Panel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
88
All Time:
1,821
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Before you begin disassembly, be sure to have the necessary tool. You will need a Torx size T6 screwdriver. You will be removing the stylus in order to take off the back panel.
    1. Palm m500 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the stylus from the side of the PDA by sliding it upwards.
      Ask FixBot
    2. Palm m500 Back Panel Replacement: step 2, image 1 of 2 Palm m500 Back Panel Replacement: step 2, image 2 of 2
      • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
      • Place screws in a plastic bag or another safe place.
      Ask FixBot
    3. Palm m500 Back Panel Replacement: step 3, image 1 of 3 Palm m500 Back Panel Replacement: step 3, image 2 of 3 Palm m500 Back Panel Replacement: step 3, image 3 of 3
      • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
      • Carefully and forcefully pry the panels apart.
      Ask FixBot
Author
with
Alex Haggblade
104 Reputation
1 Guide authored
Cal Poly, Team 14-9, Forte Winter 2011 Member of Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 88
All Time: 1,821
