Up to 20% off select tools
Palm m105 Display Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
32
All Time:
1,230
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help you remove and replace the screen found in the Palm m105.
The Palm m105 has a LCD screen with a thin plastic cover. It not only allows the stylus to interact with its different applications but also displays the information necessary for a PDA. Problems can arise from the screen's cheap wiring and damage to the plastic digitizers caused by stylus use over time. Thus, the device becomes unusable because nothing is displayed. This means a screen replacement in most cases but see the Palm m105 troubleshooting page to see if other issues are preventing it from working correctly. Also make sure to remove the two AAA batteries before getting started.
    1. Palm m105 Display Screen Replacement, Display Screen: step 1, image 1 of 1
      • Flip the protective cover open and pull it straight away from the device to release the two clips.
      Ask FixBot
    2. Palm m105 Display Screen Replacement: step 2, image 1 of 1
      • To remove the faceplate, locate the tab at the top of the device.
      • Lift the tab upwards with your finger.
      • The tab releases easily. Excessive force is not required.
      Ask FixBot
    3. Palm m105 Display Screen Replacement: step 3, image 1 of 2 Palm m105 Display Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      T5 Torx Screwdriver
      $5.49
      Buy
      • Using a T5 Torx screwdriver, remove the four screws located on the back of the device.
      • With the screws removed, the device is separated into two parts (the empty back cover and the back case holding the main components).
      Ask FixBot
    4. Palm m105 Display Screen Replacement: step 4, image 1 of 1
      • Be careful with this step. The motherboard and screen are attached by fragile cables.
      • Slowly lift the motherboard and the screen from the back case.
      • Gently hold the screen back so that you see the cables between it and the motherboard.
      Ask FixBot
    5. Palm m105 Display Screen Replacement: step 5, image 1 of 2 Palm m105 Display Screen Replacement: step 5, image 2 of 2
      • Detach the screen from the motherboard by carefully pulling up on the three tabs.
      • Be careful. These tabs are fragile.
      • The motherboard and screen separate once the three tabs are released.
      • Recycle the old screen.
      Ask FixBot
Author
with
Erik Thompson
31 Reputation
5 Guides authored
UW Stout, Team 1-3, Zhou Fall 2011 Member of UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 32
All Time: 1,230
