Palm m105 Batteries Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
31
All Time:
1,777
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 seconds
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
You will need to have a supply of AAA batteries for replacement. Can be found at most hardware and department stores. You can also order them online here
    1. Palm m105 Batteries Replacement, Batteries: step 1, image 1 of 1
      • Press the latch on the battery door on the back of the device and pull outwards.
      • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
      Ask FixBot
    2. Palm m105 Batteries Replacement: step 2, image 1 of 1
      • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
      • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
      Ask FixBot
    3. Palm m105 Batteries Replacement: step 3, image 1 of 1
      • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
      Ask FixBot
Erik Thompson
31 Reputation
5 Guides authored
UW Stout, Team 1-3, Zhou Fall 2011 Member of UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Members
84 Guides authored
2 Guide Comments
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - Reply Share
I have on that doesn't use batteries. It's a rechargeable one. Do you have any instructions on how to replace the internal battery?
deanplays - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 1,777
