Up to 20% off select tools
Palm m 100 Display Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
29
All Time:
1,172
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide will provide instructions and visuals on how to replace the display screen.
    1. Palm m 100 Display Screen Replacement, Display Screen: step 1, image 1 of 1
      • Remove the batteries.
      Ask FixBot
    2. Palm m 100 Display Screen Replacement: step 2, image 1 of 1
      • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
      Ask FixBot
    3. Palm m 100 Display Screen Replacement: step 3, image 1 of 1
      • Remove rear cover by gently lifting it up from the bottom.
      Ask FixBot
    4. Palm m 100 Display Screen Replacement: step 4, image 1 of 1
      • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
      • Lift the left side of the circuit board and open it as though it were a book.
      Ask FixBot
    5. Palm m 100 Display Screen Replacement: step 5, image 1 of 2 Palm m 100 Display Screen Replacement: step 5, image 2 of 2
      • Unplug the three connectors located on the right side of the circuit board with great caution and care.
      • Slide the cables out gently using a spudger
      • Separate the screen from the board.
      Ask FixBot
Author
with
Lexi Gallucci
11 Reputation
2 Guides authored
James Madison, Team 1-3, Allen Fall 2011 Member of James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,172
