Up to 20% off select tools
Palm Zire 31 Screen Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
94
All Time:
3,218
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you know that your screen needs to be replaced, this guide will show you how to do so.
    1. Palm Zire 31 Screen Replacement, Case: step 1, image 1 of 1
      • Unscrew the two 7.35mm Torx T6 screws.
      Ask FixBot
    2. Palm Zire 31 Screen Replacement: step 2, image 1 of 1
      • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
      Ask FixBot
    3. Palm Zire 31 Screen Replacement: step 3, image 1 of 1
      • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
      Ask FixBot
    4. Palm Zire 31 Screen Replacement: step 4, image 1 of 1
      • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
      Ask FixBot
    1. Palm Zire 31 Screen Replacement, Screen: step 5, image 1 of 1
      • Carefully pull back the brown cable holders and separate the screen from the motherboard.
      Ask FixBot
Author
with
Gabe
501 Reputation
5 Guides authored
Cal Poly, Team 5-21, Amido Winter 2011 Member of Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 94
All Time: 3,218
