Palm Zire 31 Keys Replacement
    1. Palm Zire 31 Keys Replacement, Case: step 1, image 1 of 1
      • Unscrew the two 7.35mm Torx T6 screws.
      Ask FixBot
    2. Palm Zire 31 Keys Replacement: step 2, image 1 of 1
      • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
      Ask FixBot
    3. Palm Zire 31 Keys Replacement: step 3, image 1 of 1
      • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
      Ask FixBot
    4. Palm Zire 31 Keys Replacement: step 4, image 1 of 1
      • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
      Ask FixBot
    1. Palm Zire 31 Keys Replacement, Keys: step 5, image 1 of 1
      • The blue keys will either come off with the blue front case, or stay on the motherboard.
      Ask FixBot
Gabe
501 Reputation
5 Guides authored
Cal Poly, Team 5-21, Amido Winter 2011 Member of Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 964
