Up to 20% off select tools
Palm Vx Screen Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
34
All Time:
2,683
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
In this repair guide it will be described how to replace a broken screen on a Palm Vx orgainizer.
    1. Palm Vx Screen Replacement, Screen: step 1, image 1 of 1
      • Take protective cover off of organizer.
      • Note: cover slides off like pointer pen.
      Ask FixBot
    2. Palm Vx Screen Replacement: step 2, image 1 of 1
      • Lay device face down on surface.
      Ask FixBot
    3. Palm Vx Screen Replacement: step 3, image 1 of 2 Palm Vx Screen Replacement: step 3, image 2 of 2
      • Heat each side for 30 seconds individually.
      • Note: Be aware not to heat the screen, or any part to the point of damage.
      • Caution: Heating the metal case may cause burns.
      Ask FixBot
    4. Palm Vx Screen Replacement: step 4, image 1 of 3 Palm Vx Screen Replacement: step 4, image 2 of 3 Palm Vx Screen Replacement: step 4, image 3 of 3
      • Pry off each side individually using a plastic pry bar.
      • Note: Using a plastic pry bar will keep from damaging the case. DO NOT use a metal screwdriver or similar tool.
      • Repeat for front and back of PDA.
      • Note: Do not lose the green power button that may fall out.
      Ask FixBot
    5. Palm Vx Screen Replacement: step 5, image 1 of 1
      • Remove the screen from the plastic casing.
      Ask FixBot
    6. Palm Vx Screen Replacement: step 6, image 1 of 2 Palm Vx Screen Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
      • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
      • Once the clamp is up you can use the tweezers to gently detach the ribbon.
      Ask FixBot
    7. Palm Vx Screen Replacement: step 7, image 1 of 1
      • Now you must flip up the adjacent clamp as well, using tweezers like before.
      • After the clamp is flipped you can gently remove the second ribbon with tweezers.
      Ask FixBot
    8. Palm Vx Screen Replacement: step 8, image 1 of 1
      • Before removing the screen you must detach one more wire, the battery connector.
      • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
      • Do not pull on the wire.
      Ask FixBot
    9. Palm Vx Screen Replacement: step 9, image 1 of 2 Palm Vx Screen Replacement: step 9, image 2 of 2
      • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
      Ask FixBot
Author
with
Will Doornink
11 Reputation
1 Guide authored
UW Stout, Team 5-4, Zhou Fall 2011 Member of UW Stout, Team 5-4, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 34
All Time: 2,683
