Palm Treo Pro Motherboard Replacement
    1. Palm Treo Pro Motherboard Replacement, Battery: step 1, image 1 of 3 Palm Treo Pro Motherboard Replacement, Battery: step 1, image 2 of 3 Palm Treo Pro Motherboard Replacement, Battery: step 1, image 3 of 3
      • Press down on the back of the case and slide forward to remove it.
      Ask FixBot
    2. Palm Treo Pro Motherboard Replacement: step 2, image 1 of 1
      • Remove the battery by pulling up on the tab near the camera lens.
      • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
      Ask FixBot
    1. Palm Treo Pro Motherboard Replacement, Motherboard: step 3, image 1 of 3 Palm Treo Pro Motherboard Replacement, Motherboard: step 3, image 2 of 3 Palm Treo Pro Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
      • Be careful not to misplace these screws as they are very small and will be important during reassembly.
      • If the screws are stripped a flat head screw driver may be necessary.
      Ask FixBot
    2. Palm Treo Pro Motherboard Replacement: step 4, image 1 of 3 Palm Treo Pro Motherboard Replacement: step 4, image 2 of 3 Palm Treo Pro Motherboard Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
      Ask FixBot
    3. Palm Treo Pro Motherboard Replacement: step 5, image 1 of 3 Palm Treo Pro Motherboard Replacement: step 5, image 2 of 3 Palm Treo Pro Motherboard Replacement: step 5, image 3 of 3
      • Remove the main plastic body
      • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
      • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
      Ask FixBot
    4. Palm Treo Pro Motherboard Replacement: step 6, image 1 of 3 Palm Treo Pro Motherboard Replacement: step 6, image 2 of 3 Palm Treo Pro Motherboard Replacement: step 6, image 3 of 3
      • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
      • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
      Ask FixBot
    5. Palm Treo Pro Motherboard Replacement: step 7, image 1 of 2 Palm Treo Pro Motherboard Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
      Ask FixBot
    6. Palm Treo Pro Motherboard Replacement: step 8, image 1 of 3 Palm Treo Pro Motherboard Replacement: step 8, image 2 of 3 Palm Treo Pro Motherboard Replacement: step 8, image 3 of 3
      • There are two ribbon cables under the yellow tape.
      • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
      • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
      Ask FixBot
    7. Palm Treo Pro Motherboard Replacement: step 9, image 1 of 3 Palm Treo Pro Motherboard Replacement: step 9, image 2 of 3 Palm Treo Pro Motherboard Replacement: step 9, image 3 of 3
      • Use a plastic opening tool to lift the motherboard up and out of the phone case
      • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
      • It can easily be disconnected with your fingers
      • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
      • The motherboard has now been completely removed
      Ask FixBot
Nadia Carroll
11 Reputation
1 Guide authored
Cal Poly, Team 8-59, Johann Spring 2013 Member of Cal Poly, Team 8-59, Johann Spring 2013
CPSU-JOHANN-S13S8G59
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 701
