Palm Treo 755p Antenna Replacement
  1. Palm Treo 755p Antenna Replacement, Battery: step 1, image 1 of 3 Palm Treo 755p Antenna Replacement, Battery: step 1, image 2 of 3 Palm Treo 755p Antenna Replacement, Battery: step 1, image 3 of 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
    Ask FixBot
  2. Palm Treo 755p Antenna Replacement: step 2, image 1 of 2 Palm Treo 755p Antenna Replacement: step 2, image 2 of 2
    • Remove the battery by lifting up on one side.
    Ask FixBot
  3. Palm Treo 755p Antenna Replacement, Back Cover: step 3, image 1 of 2 Palm Treo 755p Antenna Replacement, Back Cover: step 3, image 2 of 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
    Ask FixBot
  4. Palm Treo 755p Antenna Replacement: step 4, image 1 of 1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
    Ask FixBot
  5. Palm Treo 755p Antenna Replacement: step 5, image 1 of 2 Palm Treo 755p Antenna Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
    Ask FixBot
  6. Palm Treo 755p Antenna Replacement: step 6, image 1 of 2 Palm Treo 755p Antenna Replacement: step 6, image 2 of 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
    Ask FixBot
  7. Palm Treo 755p Antenna Replacement: step 7, image 1 of 3 Palm Treo 755p Antenna Replacement: step 7, image 2 of 3 Palm Treo 755p Antenna Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
    Ask FixBot
  8. Palm Treo 755p Antenna Replacement, Antenna: step 8, image 1 of 1
    • The antenna is on the back half of the phone.
    Ask FixBot
  9. Palm Treo 755p Antenna Replacement: step 9, image 1 of 2 Palm Treo 755p Antenna Replacement: step 9, image 2 of 2
    • Press in the four black clips using a spudger to pop off the upper-back cover.
    Ask FixBot
  10. Palm Treo 755p Antenna Replacement: step 10, image 1 of 1
    • Lift off the top of the back cover from the phone frame.
    Ask FixBot
  11. Palm Treo 755p Antenna Replacement: step 11, image 1 of 2 Palm Treo 755p Antenna Replacement: step 11, image 2 of 2
    • Gently pop off the antenna by pulling it away from the back cover.
    Ask FixBot
Mike Shaw
601 Reputation
6 Guides authored
Cal Poly, Team 14-6, Forte Winter 2011 Member of Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 36
All Time: 2,137
