Palm Treo 700P Motherboard Replacement
  1. Palm Treo 700P Motherboard Replacement, Battery: step 1, image 1 of 3 Palm Treo 700P Motherboard Replacement, Battery: step 1, image 2 of 3 Palm Treo 700P Motherboard Replacement, Battery: step 1, image 3 of 3
    • Press the button located just above the Sprint™ logo and then slide the cover down.
    Ask FixBot
  2. Palm Treo 700P Motherboard Replacement: step 2, image 1 of 2 Palm Treo 700P Motherboard Replacement: step 2, image 2 of 2
    • Use the small notch on the left hand side of the phone to remove the battery.
    Ask FixBot
  3. Palm Treo 700P Motherboard Replacement, Back Case: step 3, image 1 of 1
    • Remove the stylus from the phone.
    Ask FixBot
  4. Palm Treo 700P Motherboard Replacement: step 4, image 1 of 1
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
    Ask FixBot
  5. Palm Treo 700P Motherboard Replacement: step 5, image 1 of 1
    • Using the spudger, remove the small rubberized patch under the antenna.
    Ask FixBot
  6. Palm Treo 700P Motherboard Replacement: step 6, image 1 of 1
    • Unscrew the last two screws using the previous screw driver.
    Ask FixBot
  7. Palm Treo 700P Motherboard Replacement: step 7, image 1 of 2 Palm Treo 700P Motherboard Replacement: step 7, image 2 of 2
    • Using the plastic opening tool, gently separate the back case from the phone body.
    Ask FixBot
  8. Palm Treo 700P Motherboard Replacement, Motherboard: step 8, image 1 of 3 Palm Treo 700P Motherboard Replacement, Motherboard: step 8, image 2 of 3 Palm Treo 700P Motherboard Replacement, Motherboard: step 8, image 3 of 3
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
    Ask FixBot
  9. Palm Treo 700P Motherboard Replacement: step 9, image 1 of 3 Palm Treo 700P Motherboard Replacement: step 9, image 2 of 3 Palm Treo 700P Motherboard Replacement: step 9, image 3 of 3
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
    Ask FixBot
  10. Palm Treo 700P Motherboard Replacement: step 10, image 1 of 2 Palm Treo 700P Motherboard Replacement: step 10, image 2 of 2
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
    Ask FixBot
  11. Palm Treo 700P Motherboard Replacement: step 11, image 1 of 3 Palm Treo 700P Motherboard Replacement: step 11, image 2 of 3 Palm Treo 700P Motherboard Replacement: step 11, image 3 of 3
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
    Ask FixBot
Ivan
11 Reputation
1 Guide authored
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 34
All Time: 1,188
