Palm Treo 700P LCD Replacement
    1. Palm Treo 700P LCD Replacement, Battery: step 1, image 1 of 3 Palm Treo 700P LCD Replacement, Battery: step 1, image 2 of 3 Palm Treo 700P LCD Replacement, Battery: step 1, image 3 of 3
      • Press the button located just above the Sprint™ logo and then slide the cover down.
      Ask FixBot
    2. Palm Treo 700P LCD Replacement: step 2, image 1 of 2 Palm Treo 700P LCD Replacement: step 2, image 2 of 2
      • Use the small notch on the left hand side of the phone to remove the battery.
      Ask FixBot
    1. Palm Treo 700P LCD Replacement, Back Case: step 3, image 1 of 1
      • Remove the stylus from the phone.
      Ask FixBot
    2. Palm Treo 700P LCD Replacement: step 4, image 1 of 1
      • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
      Ask FixBot
    3. Palm Treo 700P LCD Replacement: step 5, image 1 of 1
      • Using the spudger, remove the small rubberized patch under the antenna.
      Ask FixBot
    4. Palm Treo 700P LCD Replacement: step 6, image 1 of 1
      • Unscrew the last two screws using the previous screw driver.
      Ask FixBot
    5. Palm Treo 700P LCD Replacement: step 7, image 1 of 2 Palm Treo 700P LCD Replacement: step 7, image 2 of 2
      • Using the plastic opening tool, gently separate the back case from the phone body.
      Ask FixBot
    1. Palm Treo 700P LCD Replacement, Motherboard: step 8, image 1 of 3 Palm Treo 700P LCD Replacement, Motherboard: step 8, image 2 of 3 Palm Treo 700P LCD Replacement, Motherboard: step 8, image 3 of 3
      • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
      Ask FixBot
    2. Palm Treo 700P LCD Replacement: step 9, image 1 of 3 Palm Treo 700P LCD Replacement: step 9, image 2 of 3 Palm Treo 700P LCD Replacement: step 9, image 3 of 3
      • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
      • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
      Ask FixBot
    3. Palm Treo 700P LCD Replacement: step 10, image 1 of 2 Palm Treo 700P LCD Replacement: step 10, image 2 of 2
      • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
      • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
      Ask FixBot
    4. Palm Treo 700P LCD Replacement: step 11, image 1 of 3 Palm Treo 700P LCD Replacement: step 11, image 2 of 3 Palm Treo 700P LCD Replacement: step 11, image 3 of 3
      • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
      • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
      Ask FixBot
    1. Palm Treo 700P LCD Replacement, LCD: step 12, image 1 of 1
      • Once the motherboard is removed, the LCD should be resting on the front case of the phone.
      Ask FixBot
Lucas
26 Reputation
1 Guide authored
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,176
