Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to remove the keypad of the cell phone
Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Once the motherboard is removed, the LCD should be resting on the front case of the phone.
