Up to 20% off select tools
Palm Treo 700P Camera Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
12
All Time:
1,073
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Palm Treo 700P Camera Replacement, Battery: step 1, image 1 of 3 Palm Treo 700P Camera Replacement, Battery: step 1, image 2 of 3 Palm Treo 700P Camera Replacement, Battery: step 1, image 3 of 3
      • Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
      Ask FixBot
    2. Palm Treo 700P Camera Replacement: step 2, image 1 of 2 Palm Treo 700P Camera Replacement: step 2, image 2 of 2
      • Use the small notch on the left hand side of the phone to remove the battery.
      Ask FixBot
    1. Palm Treo 700P Camera Replacement, Back Case: step 3, image 1 of 1
      • Remove the stylus from the phone.
      Ask FixBot
    2. Palm Treo 700P Camera Replacement: step 4, image 1 of 1
      • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
      Ask FixBot
    3. Palm Treo 700P Camera Replacement: step 5, image 1 of 1
      • Using the spudger, remove the small rubberized patch under the antenna.
      Ask FixBot
    4. Palm Treo 700P Camera Replacement: step 6, image 1 of 1
      • Unscrew the last two screws using the previous screw driver.
      Ask FixBot
    5. Palm Treo 700P Camera Replacement: step 7, image 1 of 2 Palm Treo 700P Camera Replacement: step 7, image 2 of 2
      • Using the plastic opening tool, gently separate the back case from the phone body.
      Ask FixBot
    1. Palm Treo 700P Camera Replacement, Motherboard: step 8, image 1 of 3 Palm Treo 700P Camera Replacement, Motherboard: step 8, image 2 of 3 Palm Treo 700P Camera Replacement, Motherboard: step 8, image 3 of 3
      • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
      Ask FixBot
    2. Palm Treo 700P Camera Replacement: step 9, image 1 of 3 Palm Treo 700P Camera Replacement: step 9, image 2 of 3 Palm Treo 700P Camera Replacement: step 9, image 3 of 3
      • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
      • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
      Ask FixBot
    3. Palm Treo 700P Camera Replacement: step 10, image 1 of 2 Palm Treo 700P Camera Replacement: step 10, image 2 of 2
      • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
      • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
      Ask FixBot
    4. Palm Treo 700P Camera Replacement: step 11, image 1 of 3 Palm Treo 700P Camera Replacement: step 11, image 2 of 3 Palm Treo 700P Camera Replacement: step 11, image 3 of 3
      • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
      • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
      Ask FixBot
    1. Palm Treo 700P Camera Replacement, Camera: step 12, image 1 of 1
      • Using the plastic opening tool, loosen the metal camera holder.
      Ask FixBot
    2. Palm Treo 700P Camera Replacement: step 13, image 1 of 1
      • Once the camera holder is loose, gently detach it from the camera.
      Ask FixBot
Author
with
John Rainier Solanzo
7 Reputation
2 Guides authored
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Members
84 Guides authored
1 Guide Comment
Does anyone know where or how to get a developers guide or geeks guide to tearing this phone down completely? I have a number of these, as well as old Galaxy Note phones, a broken S7 etc. And I would love to have the blueprint to know how to hack a LTE antenae, and S7 camera into my treo palm 700p..Wouldn't that be awesome? I still like it better than the modern smart phone, and just lost use of it when my carrier killed CDMA last week> :-(
peterveri - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,073
