Up to 20% off select tools
Palm Treo 700P Back Case Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
25
All Time:
1,152
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Palm Treo 700P Back Case Replacement, Battery: step 1, image 1 of 3 Palm Treo 700P Back Case Replacement, Battery: step 1, image 2 of 3 Palm Treo 700P Back Case Replacement, Battery: step 1, image 3 of 3
      • Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
      Ask FixBot
    2. Palm Treo 700P Back Case Replacement: step 2, image 1 of 2 Palm Treo 700P Back Case Replacement: step 2, image 2 of 2
      • Use the small notch on the left hand side of the phone to remove the battery.
      Ask FixBot
    1. Palm Treo 700P Back Case Replacement, Back Case: step 3, image 1 of 1
      • Remove the stylus from the phone.
      Ask FixBot
    2. Palm Treo 700P Back Case Replacement: step 4, image 1 of 1
      • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
      Ask FixBot
    3. Palm Treo 700P Back Case Replacement: step 5, image 1 of 1
      • Using the spudger, remove the small rubberized patch under the antenna.
      Ask FixBot
    4. Palm Treo 700P Back Case Replacement: step 6, image 1 of 1
      • Unscrew the last two screws using the previous screw driver.
      Ask FixBot
    5. Palm Treo 700P Back Case Replacement: step 7, image 1 of 2 Palm Treo 700P Back Case Replacement: step 7, image 2 of 2
      • Using the plastic opening tool, gently separate the back case from the phone body.
      Ask FixBot
2 other people completed this guide.
Author
with
James Smith
10 Reputation
3 Guides authored
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,152
