Palm Treo 700P Antenna Replacement
    1. Palm Treo 700P Antenna Replacement, Battery: step 1, image 1 of 3 Palm Treo 700P Antenna Replacement, Battery: step 1, image 2 of 3 Palm Treo 700P Antenna Replacement, Battery: step 1, image 3 of 3
      • Press the button located just above the Sprint™ logo and then slide the cover down.
      Ask FixBot
    2. Palm Treo 700P Antenna Replacement: step 2, image 1 of 2 Palm Treo 700P Antenna Replacement: step 2, image 2 of 2
      • Use the small notch on the left hand side of the phone to remove the battery.
      Ask FixBot
    1. Palm Treo 700P Antenna Replacement, Antenna: step 3, image 1 of 1
      • Remove the stylus from the phone.
      Ask FixBot
    2. Palm Treo 700P Antenna Replacement: step 4, image 1 of 1
      • After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
      Ask FixBot
    3. Palm Treo 700P Antenna Replacement: step 5, image 1 of 1
      • Using the spudger, remove the small rubberized patch under the antenna.
      Ask FixBot
    4. Palm Treo 700P Antenna Replacement: step 6, image 1 of 1
      • Unscrew the last two screws using the same T-5 Torx screw driver.
      Ask FixBot
    5. Palm Treo 700P Antenna Replacement: step 7, image 1 of 1
      • Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
      Ask FixBot
    6. Palm Treo 700P Antenna Replacement: step 8, image 1 of 1
      • The antenna will now be loose, gently pull the antenna out of the phone.
      Ask FixBot
John Rainier Solanzo
7 Reputation
2 Guides authored
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,087
