Palm Treo 680 Microphone Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
92
All Time:
4,726
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This shows you how to replace a faulty microphone for the Palm Treo 680.
Tools
    1. Palm Treo 680 Microphone Replacement, Battery: step 1, image 1 of 2 Palm Treo 680 Microphone Replacement, Battery: step 1, image 2 of 2
      • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
      Ask FixBot
    2. Palm Treo 680 Microphone Replacement: step 2, image 1 of 1
      • Remove the battery by pulling it out towards you.
      Ask FixBot
    1. Palm Treo 680 Microphone Replacement, Back Panel: step 3, image 1 of 2 Palm Treo 680 Microphone Replacement, Back Panel: step 3, image 2 of 2
      • Remove the stylus in order to access the screw.
      • Remove the 27mm top-left screw using a T6 Torx screwdriver.
      Ask FixBot
    2. Palm Treo 680 Microphone Replacement: step 4, image 1 of 2 Palm Treo 680 Microphone Replacement: step 4, image 2 of 2
      • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
      • Remove the 27mm screw using the T6 Torx screwdriver.
      • If there is a red Palm sticker covering this screw, puncture it to access the screw.
      Ask FixBot
    3. Palm Treo 680 Microphone Replacement: step 5, image 1 of 1
      • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
      Ask FixBot
    4. Palm Treo 680 Microphone Replacement: step 6, image 1 of 3 Palm Treo 680 Microphone Replacement: step 6, image 2 of 3 Palm Treo 680 Microphone Replacement: step 6, image 3 of 3
      • Turn the phone so the screen is facing the right side.
      • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
      • Separate the covers from the left side of the device as indicated in the picture.
      • The right side contains orange ribbons that are easily damaged.
      Ask FixBot
    1. Palm Treo 680 Microphone Replacement, Microphone: step 7, image 1 of 2 Palm Treo 680 Microphone Replacement, Microphone: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of tweezers, grasp the blue rubber microphone.
      • Pull the rubber microphone up and back to remove it.
      • Now you have successfully removed the microphone.
      Ask FixBot
2 other people completed this guide.
Maiya123
99 Reputation
6 Guides authored
Cal Poly, Team 6-4, Maness Fall 2009 Member of Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 92
All Time: 4,726
