Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓This guide shows you how to repair a disfunctional keyboard for the Palm Treo 680.
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Slide the slim metal plate upwards until it disconnects from the motherboard.
Carefully turn the phone over so the screen is face up.
Locate the other orange ribbon that connects the motherboard to the faceplate.
Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
Separate the motherboard and faceplate of the Palm Treo.
Locate the backside of the Treo's faceplate.
Remove the two screws using the T6 Torx screwdriver.
