Palm Treo 650 Case Replacement
    1. Palm Treo 650 Case Replacement, Battery and Stylus: step 1, image 1 of 1
      • Position the phone so the screen faces down.
      • Remove the stylus found on the back of the phone.
      Ask FixBot
    2. Palm Treo 650 Case Replacement: step 2, image 1 of 1
      • Hold the button in the middle of the phone's back to remove the battery cover.
      • Slide the cover down to remove it, and set the cover aside.
      Ask FixBot
    3. Palm Treo 650 Case Replacement: step 3, image 1 of 2 Palm Treo 650 Case Replacement: step 3, image 2 of 2
      • Lift the edge of the battery, separating contact points, and pull out as pictured.
      Ask FixBot
    1. Palm Treo 650 Case Replacement, Case: step 4, image 1 of 1
      • Remove the round, rubber cover to expose a screw that will be removed in the next step.
      Ask FixBot
    2. Palm Treo 650 Case Replacement: step 5, image 1 of 2 Palm Treo 650 Case Replacement: step 5, image 2 of 2
      • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
      • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
      Ask FixBot
    3. Palm Treo 650 Case Replacement: step 6, image 1 of 1
      • Pull the antenna outward to remove the antenna from the body of the phone.
      Ask FixBot
    4. Palm Treo 650 Case Replacement: step 7, image 1 of 2 Palm Treo 650 Case Replacement: step 7, image 2 of 2
      • Pry the back cover off using an iFixit opening tool.
      • Several small clips on the inside attach to the back cover.
      Ask FixBot
3 other people completed this guide.
mmedrano
101 Reputation
2 Guides authored
Cal Poly, Team 19-3, Maness Fall 2009 Member of Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 3,483
