Palm Treo 600 Logic Board Replacement
  1. Palm Treo 600 Logic Board Replacement, Back Case: step 1, image 1 of 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    Ask FixBot
  2. Palm Treo 600 Logic Board Replacement: step 2, image 1 of 2 Palm Treo 600 Logic Board Replacement: step 2, image 2 of 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
    Ask FixBot
  3. Palm Treo 600 Logic Board Replacement: step 3, image 1 of 2 Palm Treo 600 Logic Board Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
    Ask FixBot
  4. Palm Treo 600 Logic Board Replacement, Motherboard: step 4, image 1 of 1
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
    Ask FixBot
  5. Palm Treo 600 Logic Board Replacement: step 5, image 1 of 1
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
    Ask FixBot
  6. Palm Treo 600 Logic Board Replacement: step 6, image 1 of 1
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
    Ask FixBot
  7. Palm Treo 600 Logic Board Replacement: step 7, image 1 of 2 Palm Treo 600 Logic Board Replacement: step 7, image 2 of 2
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
    Ask FixBot
Clement Poisson
24 Reputation
7 Guides authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,839
