Up to 20% off select tools
Palm Treo 600 Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
16
All Time:
1,920
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
  • iFixit Opening Tool
    4.8
  • Tweezers
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Replace the keyboard!!
    1. Palm Treo 600 Keyboard Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
      Ask FixBot
    2. Palm Treo 600 Keyboard Replacement: step 2, image 1 of 2 Palm Treo 600 Keyboard Replacement: step 2, image 2 of 2
      • Use the T6 Torx Screwdriver to remove all 4 screws.
      • You have to first remove the Stylus to access the 4th screw.
      Ask FixBot
    3. Palm Treo 600 Keyboard Replacement: step 3, image 1 of 2 Palm Treo 600 Keyboard Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, carefully separate the front and back cases.
      • Note: The antenna will detach from the phone.
      Ask FixBot
    1. Palm Treo 600 Keyboard Replacement, Front Case: step 4, image 1 of 2 Palm Treo 600 Keyboard Replacement, Front Case: step 4, image 2 of 2
      • Using a T6 Torx Screwdriver, remove the two screws.
      • The motherboard will now be loose from the front case.
      Ask FixBot
    1. Palm Treo 600 Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Using the spudger, flip open the clasp that holds the data ribbon in place.
      Ask FixBot
    2. Palm Treo 600 Keyboard Replacement: step 6, image 1 of 1
      • Pull out the ribbon.
      • The keyboard will disconnect from the phone.
      Ask FixBot
Author
with
Clement Poisson
24 Reputation
7 Guides authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,920
