Palm Treo 600 Front Case Replacement
    1. Palm Treo 600 Front Case Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
      Ask FixBot
    2. Palm Treo 600 Front Case Replacement: step 2, image 1 of 2 Palm Treo 600 Front Case Replacement: step 2, image 2 of 2
      • Use the T6 Torx Screwdriver to remove all 4 screws.
      • You have to first remove the Stylus to access the 4th screw.
      Ask FixBot
    3. Palm Treo 600 Front Case Replacement: step 3, image 1 of 2 Palm Treo 600 Front Case Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, carefully separate the front and back cases.
      • Note: The antenna will detach from the phone.
      Ask FixBot
    1. Palm Treo 600 Front Case Replacement, Front Case: step 4, image 1 of 2 Palm Treo 600 Front Case Replacement, Front Case: step 4, image 2 of 2
      • Using a T6 Torx Screwdriver, remove the two screws.
      • The motherboard will now be loose from the front case.
      Ask FixBot
Michael Polka
22 Reputation
1 Guide authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 2,917
