Up to 20% off select tools
Palm Treo 600 Camera Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
24
All Time:
1,901
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
    1. Palm Treo 600 Camera Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
      Ask FixBot
    2. Palm Treo 600 Camera Replacement: step 2, image 1 of 2 Palm Treo 600 Camera Replacement: step 2, image 2 of 2
      • Use the T6 Torx Screwdriver to remove all 4 screws.
      • You have to first remove the Stylus to access the 4th screw.
      Ask FixBot
    3. Palm Treo 600 Camera Replacement: step 3, image 1 of 2 Palm Treo 600 Camera Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, carefully separate the front and back cases.
      • Note: The antenna will detach from the phone.
      Ask FixBot
    1. Palm Treo 600 Camera Replacement, Motherboard: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
      Ask FixBot
    2. Palm Treo 600 Camera Replacement: step 5, image 1 of 1
      • Lift up the silver casing.
      • Careful! The casing is connected to the body. Pull the casing up.
      Ask FixBot
    3. Palm Treo 600 Camera Replacement: step 6, image 1 of 1
      • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
      Ask FixBot
    4. Palm Treo 600 Camera Replacement: step 7, image 1 of 2 Palm Treo 600 Camera Replacement: step 7, image 2 of 2
      • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
      Ask FixBot
    1. Palm Treo 600 Camera Replacement, Camera: step 8, image 1 of 2 Palm Treo 600 Camera Replacement, Camera: step 8, image 2 of 2
      • Using the flat end of the spudger, lift the metal case off of the camera.
      Ask FixBot
    2. Palm Treo 600 Camera Replacement: step 9, image 1 of 3 Palm Treo 600 Camera Replacement: step 9, image 2 of 3 Palm Treo 600 Camera Replacement: step 9, image 3 of 3
      • Slide the flat end of the spudger between the printed circuit board and metal holder.
      • Pop the camera up
      Ask FixBot
Author
with
Clement Poisson
24 Reputation
7 Guides authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,901
