Palm Treo 600 Battery Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
57
All Time:
6,275
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Follow this guide if the battery is dysfunctional and you want to replace it.
Tools
  • Tweezers
    4.9
  • Spudger
    4.9
    1. Palm Treo 600 Battery Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
      Ask FixBot
    2. Palm Treo 600 Battery Replacement: step 2, image 1 of 2 Palm Treo 600 Battery Replacement: step 2, image 2 of 2
      • Use the T6 Torx Screwdriver to remove all 4 screws.
      • You have to first remove the Stylus to access the 4th screw.
      Ask FixBot
    3. Palm Treo 600 Battery Replacement: step 3, image 1 of 2 Palm Treo 600 Battery Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, carefully separate the front and back cases.
      • Note: The antenna will detach from the phone.
      Ask FixBot
    1. Palm Treo 600 Battery Replacement, Battery: step 4, image 1 of 2 Palm Treo 600 Battery Replacement, Battery: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using metal tweezers, unplug small white plug.
      • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
      Ask FixBot
    2. Palm Treo 600 Battery Replacement: step 5, image 1 of 1
      • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
      • The battery may be glued to the phone.
      Ask FixBot
2 other people completed this guide.
Clement Poisson
24 Reputation
7 Guides authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 57
All Time: 6,275
