Introduction
This guide will walk you through the steps to remove the motherboard on a Palm T|X.
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Use a soldering iron to disconnect the battery wires from the motherboard.
For soldering instructions, you can view the Soldering Guide.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
