Up to 20% off select tools
Palm TX Front Panel Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,493
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the steps to remove and replace the front panel on a Palm T|X.
    1. Palm TX Front Panel Replacement, Back Panel: step 1, image 1 of 2 Palm TX Front Panel Replacement, Back Panel: step 1, image 2 of 2
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      Ask FixBot
    2. Palm TX Front Panel Replacement: step 2, image 1 of 1
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      Ask FixBot
    3. Palm TX Front Panel Replacement: step 3, image 1 of 2 Palm TX Front Panel Replacement: step 3, image 2 of 2
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      Ask FixBot
    4. Palm TX Front Panel Replacement: step 4, image 1 of 2 Palm TX Front Panel Replacement: step 4, image 2 of 2
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      Ask FixBot
    5. Palm TX Front Panel Replacement: step 5, image 1 of 2 Palm TX Front Panel Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      Ask FixBot
    1. Palm TX Front Panel Replacement, Motherboard: step 6, image 1 of 2 Palm TX Front Panel Replacement, Motherboard: step 6, image 2 of 2
      • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
      Ask FixBot
    2. Palm TX Front Panel Replacement: step 7, image 1 of 2 Palm TX Front Panel Replacement: step 7, image 2 of 2
      • Lift the mother board out of the device.
      • A weak adhesive attaches the motherboard to the device.
      • The red wire in the picture will not be attached to your device at this point.
      Ask FixBot
    1. Palm TX Front Panel Replacement, Display: step 8, image 1 of 1
      • Orient the device sideways, as shown in the picture.
      • Lightly push the front of the display to separate it from the front panel.
      • The battery in the picture will not be attached to the device at this point.
      Ask FixBot
    1. Palm TX Front Panel Replacement, Buttons and Connector Assembly: step 9, image 1 of 1
      • Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
      • It may take some manipulation to remove the screws.
      Ask FixBot
    2. Palm TX Front Panel Replacement: step 10, image 1 of 1
      • Lift the button and connector assembly from the front panel.
      Ask FixBot
    1. Palm TX Front Panel Replacement, Front Panel: step 11, image 1 of 2 Palm TX Front Panel Replacement, Front Panel: step 11, image 2 of 2
      • Lift the rubber buttons off the front panel.
      Ask FixBot
2 other people completed this guide.
Author
with
Jake Shiraki
125 Reputation
1 Guide authored
Cal Poly, Team 1-15, Amido Winter 2011 Member of Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,493
