Up to 20% off select tools
Palm TX Back Panel Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
108
All Time:
2,402
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Removing the back panel allows you to access the various parts of the Palm T|X PDA.
    1. Palm TX Back Panel Replacement, Back Panel: step 1, image 1 of 2 Palm TX Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      Ask FixBot
    2. Palm TX Back Panel Replacement: step 2, image 1 of 1
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      Ask FixBot
    3. Palm TX Back Panel Replacement: step 3, image 1 of 2 Palm TX Back Panel Replacement: step 3, image 2 of 2
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      Ask FixBot
    4. Palm TX Back Panel Replacement: step 4, image 1 of 2 Palm TX Back Panel Replacement: step 4, image 2 of 2
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      Ask FixBot
    5. Palm TX Back Panel Replacement: step 5, image 1 of 2 Palm TX Back Panel Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      Ask FixBot
Author
with
Spencer Lewson
793 Reputation
6 Guides authored
Cal Poly, Team 1-15, Amido Winter 2011 Member of Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 108
All Time: 2,402
