Up to 20% off select tools
Palm Rest Disassembly
Views: 2.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
108
All Time:
2,443
Comments: 11
11 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
Follow this disassembly to remove the top casing of your laptop.
    1. Palm Rest Disassembly, Battery: step 1, image 1 of 1
      • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
      Ask FixBot
    2. Palm Rest Disassembly: step 2, image 1 of 2 Palm Rest Disassembly: step 2, image 2 of 2
      • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
      Ask FixBot
    3. Palm Rest Disassembly: step 3, image 1 of 2 Palm Rest Disassembly: step 3, image 2 of 2
      • Locate the battery and the two switches that release the battery when they are unlocked.
      Ask FixBot
    4. Palm Rest Disassembly: step 4, image 1 of 2 Palm Rest Disassembly: step 4, image 2 of 2
      • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
      Ask FixBot
    5. Palm Rest Disassembly: step 5, image 1 of 3 Palm Rest Disassembly: step 5, image 2 of 3 Palm Rest Disassembly: step 5, image 3 of 3
      • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
      • While holding the switch in place, use your right hand to gently remove the battery from its port.
      Ask FixBot
    1. Palm Rest Disassembly, Palm Rest Disassembly: step 6, image 1 of 1
      • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
      Ask FixBot
    2. Palm Rest Disassembly: step 7, image 1 of 1
      • Pry up and detach the keyboard. Starting at the top, slowly work the side and pull the keyboard away from you to unseat the bottom tabs.
      Ask FixBot
    3. Palm Rest Disassembly: step 8, image 1 of 1
      • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
      Ask FixBot
    4. Palm Rest Disassembly: step 9, image 1 of 2 Palm Rest Disassembly: step 9, image 2 of 2
      • Remove the palm rest using the blue spudger tool.
      Ask FixBot
    5. Palm Rest Disassembly: step 10, image 1 of 1
      • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
      Ask FixBot
    6. Palm Rest Disassembly: step 11, image 1 of 1
      • Remove metal keyboard underlayment.
      • There is no way to separate the palm rest from the keyboard. They both are removed as an assembly.
      Ask FixBot
Author
with
Benjamin Poirier
503 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 108
All Time: 2,443
