Up to 20% off select tools
Palm Pre Speaker Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
89
All Time:
1,815
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • T4 Torx Screwdriver
    4.8
    1. Palm Pre Speaker Replacement, Battery: step 1, image 1 of 1
      • Make sure your Palm Pre is turned off before disassembling the phone.
      • Snap off the back panel to reveal the battery.
      Ask FixBot
    2. Palm Pre Speaker Replacement: step 2, image 1 of 1
      • Carefully pull up on the tab to remove the current battery.
      Ask FixBot
    1. Palm Pre Speaker Replacement, Speaker: step 3, image 1 of 2 Palm Pre Speaker Replacement, Speaker: step 3, image 2 of 2
      • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
      Ask FixBot
    2. Palm Pre Speaker Replacement: step 4, image 1 of 2 Palm Pre Speaker Replacement: step 4, image 2 of 2
      • Use the spudger to locate the crease at the bottom of the keyboard.
      • Carefully work your way around the phone separating the back frame from the keyboard.
      Ask FixBot
    3. Palm Pre Speaker Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
      Ask FixBot
    4. Palm Pre Speaker Replacement: step 6, image 1 of 1
      • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
      • Make sure to take note of the orientation of the speaker for re-installation.
      • Make sure not the puncture the screen on the outside of the back frame.
      Ask FixBot
Author
with
noha
139 Reputation
6 Guides authored
Cal Poly, Team 7-31, Maness Spring 2012 Member of Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 89
All Time: 1,815
