Up to 20% off select tools
Palm Pre 2 Battery Replacement
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
92
All Time:
1,010
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The following guide will show the reader how to properly remove the battery from the Palm Pre 2.
    1. Palm Pre 2 Battery Replacement, Battery: step 1, image 1 of 2 Palm Pre 2 Battery Replacement, Battery: step 1, image 2 of 2
      • Make sure your Palm Pre 2 is turned off before taking apart the phone.
      • Use a plastic opening tool to remove the rear cover. Slide the opening tool along the slit to release the plastic tabs.
      Ask FixBot
    2. Palm Pre 2 Battery Replacement: step 2, image 1 of 3 Palm Pre 2 Battery Replacement: step 2, image 2 of 3 Palm Pre 2 Battery Replacement: step 2, image 3 of 3
      • Pull on the tab to remove the battery.
      • If the battery will not connect, insert a thin piece of cardboard between where the battery lies and the phone.
      Ask FixBot
Author
with
Elliott Van Hoy
256 Reputation
2 Guides authored
IUPUI, Team S1-G6, Freund Spring 2018 Member of IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 92
All Time: 1,010
