Up to 20% off select tools
Palm IIIxe Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
26
All Time:
2,188
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Removing the batteries is a very simple process that is also a preliminary step to gaining access to the inside of the device.
    1. Palm IIIxe Battery Replacement, Battery: step 1, image 1 of 3 Palm IIIxe Battery Replacement, Battery: step 1, image 2 of 3 Palm IIIxe Battery Replacement, Battery: step 1, image 3 of 3
      • Turn the device over so it is face down and remove the stylus, and battery cover.
      Ask FixBot
    2. Palm IIIxe Battery Replacement: step 2, image 1 of 2 Palm IIIxe Battery Replacement: step 2, image 2 of 2
      • Now remove the two batteries by pulling on the cloth black tab.
      • Remember, when inserting the batteries, to keep the tab below them to make it easier to remove the batteries in the future.
      • If this tab is not visible, use the flat head screwdriver and gently pry out the batteries by pushing on the positive end (opposite the spring).
      Ask FixBot
Author
with
Jacob
1 Reputation
3 Guides authored
Cal Poly, Team 16-1, Maness Spring 2010 Member of Cal Poly, Team 16-1, Maness Spring 2010
CPSU-MANESS-S10S16G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 2,188
