Up to 20% off select tools
Palm IIIx Front Button Cluster Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
93
All Time:
1,961
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
A guide to replace a damaged, lost, or broken button cluster.
    1. Palm IIIx Front Button Cluster Replacement, Battery: step 1, image 1 of 1
      • Place the Palm IIIx face down on a flat surface.
      Ask FixBot
    2. Palm IIIx Front Button Cluster Replacement: step 2, image 1 of 1
      • Push down and lift up the battery cover to remove it.
      Ask FixBot
    3. Palm IIIx Front Button Cluster Replacement: step 3, image 1 of 1
      • Remove the old batteries one at a time.
      Ask FixBot
    1. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: step 4, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
      Ask FixBot
    2. Palm IIIx Front Button Cluster Replacement: step 5, image 1 of 1
      • Hold the device on its side, positioning your hands as shown.
      • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
      Ask FixBot
    3. Palm IIIx Front Button Cluster Replacement: step 6, image 1 of 1
      • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
      • Position your hands so you can push the screen outward with your thumbs.
      • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
      Ask FixBot
    4. Palm IIIx Front Button Cluster Replacement: step 7, image 1 of 1
      • Remove cluster by pulling on the rubber backing.
      • Clean, repair, and/or replace as neccessary.
      Ask FixBot
Author
with
David Haskell
44 Reputation
3 Guides authored
Cal Poly, Team 14-43, Regan Winter 2010 Member of Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 93
All Time: 1,961
