Up to 20% off select tools
Pacific Image Electronics CS3600 Button Spring Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
89
All Time:
715
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Before beginning, please know that you will be completely taking apart the device in order to get to the button from the inside.
    1. Pacific Image Electronics CS3600 Button Spring Replacement, Button Spring: step 1, image 1 of 1
      • Begin opening the device by unscrewing the 5 following 9mm x 7mm screws with a J1 screwdriver.
      Ask FixBot
    2. Pacific Image Electronics CS3600 Button Spring Replacement: step 2, image 1 of 1
      • Once the screws have been removed, with light force open the scanner by pulling it apart at the seam.
      Ask FixBot
    3. Pacific Image Electronics CS3600 Button Spring Replacement: step 3, image 1 of 1
      • With a JIS J0 screwdriver remove the 1 screw that is 7mm x 6mm.
      Ask FixBot
    4. Pacific Image Electronics CS3600 Button Spring Replacement: step 4, image 1 of 1
      • Lift and move the plate with the connected wires out of the way.
      Ask FixBot
    5. Pacific Image Electronics CS3600 Button Spring Replacement: step 5, image 1 of 1
      • Remove the spring and replace it with a new one.
      Ask FixBot
Author
with
Amber Berry
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 89
All Time: 715
