Up to 20% off select tools
PXN Arcade Stick Button Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
63
Past 30 Days:
294
All Time:
5,847
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Many buttons become unresponsive after time, especially for a controller built for fighting games. This guide is for replacing any buttons on your PXN Arcade Stick.
This guide applies to all buttons from any position on the controller.
    1. PXN Arcade Stick Button Replacement, Buttons: step 1, image 1 of 1
      • Place the PXN Arcade Stick on a flat surface.
      Ask FixBot
    2. PXN Arcade Stick Button Replacement: step 2, image 1 of 1
      • Turn the controller upside down.
      • Remove the four screws from the bottom of the device.
      Ask FixBot
    3. PXN Arcade Stick Button Replacement: step 3, image 1 of 1
      • Set the back cover aside, being cautious of the cable connected to the motherboard.
      • Unplug the controller converter plug.
      Ask FixBot
    4. PXN Arcade Stick Button Replacement: step 4, image 1 of 1
      • Unplug the button you wish to replace.
      Ask FixBot
    5. PXN Arcade Stick Button Replacement: step 5, image 1 of 2 PXN Arcade Stick Button Replacement: step 5, image 2 of 2
      • Push in and down on the button components.
      Ask FixBot
    6. PXN Arcade Stick Button Replacement: step 6, image 1 of 2 PXN Arcade Stick Button Replacement: step 6, image 2 of 2
      • Use a spudger to push in and up on the button housing.
      Ask FixBot
    7. PXN Arcade Stick Button Replacement: step 7, image 1 of 1
      • Line up the replacement button with the socket and push down.
      Ask FixBot
    8. PXN Arcade Stick Button Replacement: step 8, image 1 of 1
      • Push the new button down into the back case of the controller.
      Ask FixBot
Author
with
Derek Rosales
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 63
Past 30 Days: 294
All Time: 5,847
