Up to 20% off select tools
PSP Go Top Cover Replacement
Views: 7.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
129
All Time:
7,429
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your PSP Go's top cover.
    1. PSP Go Top Cover Replacement, Back Cover: step 1, image 1 of 2 PSP Go Top Cover Replacement, Back Cover: step 1, image 2 of 2
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      Ask FixBot
    2. PSP Go Top Cover Replacement: step 2, image 1 of 2 PSP Go Top Cover Replacement: step 2, image 2 of 2
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      Ask FixBot
    1. PSP Go Top Cover Replacement, Top Cover: step 3, image 1 of 1
      • Pull the top cover upwards gently from its housing.
      Ask FixBot
2 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 129
All Time: 7,429
