Up to 20% off select tools
PSP Go Bottom Plate Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
123
All Time:
8,504
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the PSP Go's bottom plate!
    1. PSP Go Bottom Plate Replacement, Back Cover: step 1, image 1 of 2 PSP Go Bottom Plate Replacement, Back Cover: step 1, image 2 of 2
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      Ask FixBot
    2. PSP Go Bottom Plate Replacement: step 2, image 1 of 2 PSP Go Bottom Plate Replacement: step 2, image 2 of 2
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      Ask FixBot
    1. PSP Go Bottom Plate Replacement, Top Cover: step 3, image 1 of 1
      • Pull the top cover upwards gently from its housing.
      Ask FixBot
    1. PSP Go Bottom Plate Replacement, Bottom Plate: step 4, image 1 of 2 PSP Go Bottom Plate Replacement, Bottom Plate: step 4, image 2 of 2
      • Remove the two Phillips screws holding the bottom plate.
      • Gently lift the bottom plate away from the device.
      Ask FixBot
3 other people completed this guide.
Author
with
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 123
All Time: 8,504
