Up to 20% off select tools
PSP Go Battery Replacement
Views: 110K
View statistics:
Past 24 Hours:
33
Past 7 Days:
116
Past 30 Days:
606
All Time:
109,644
Comments: 13
1 comment on steps, 12 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the PSP Go's battery.
    1. PSP Go Battery Replacement, Back Cover: step 1, image 1 of 2 PSP Go Battery Replacement, Back Cover: step 1, image 2 of 2
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      Ask FixBot
    2. PSP Go Battery Replacement: step 2, image 1 of 2 PSP Go Battery Replacement: step 2, image 2 of 2
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      Ask FixBot
    1. PSP Go Battery Replacement, Top Cover: step 3, image 1 of 1
      • Pull the top cover upwards gently from its housing.
      Ask FixBot
    1. PSP Go Battery Replacement, Left Trigger: step 4, image 1 of 1
      • Use a plastic opening tool to gently flip up the left trigger connector.
      Ask FixBot
    2. PSP Go Battery Replacement: step 5, image 1 of 2 PSP Go Battery Replacement: step 5, image 2 of 2
      • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
      • If necessary, repeat steps 2 and 3 to remove the right trigger button.
      Ask FixBot
    1. PSP Go Battery Replacement, Battery: step 6, image 1 of 3 PSP Go Battery Replacement, Battery: step 6, image 2 of 3 PSP Go Battery Replacement, Battery: step 6, image 3 of 3
      • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
      • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
      Ask FixBot
    2. PSP Go Battery Replacement: step 7, image 1 of 1
      • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
      • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
      • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
      Ask FixBot
    3. PSP Go Battery Replacement: step 8, image 1 of 2 PSP Go Battery Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
      • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
      Ask FixBot
23 other people completed this guide.
Author
with
12 Guide Comments
this was so quick . I have been trying to get this repaired for years, only to hear throw it away there is no fix . sharing love
mainemade4u - Reply Share
a couple of notes my cover came completely off in the beginning step without a problem or broken screws. next i didnt und the wired cabled beside the clicker and it wasnt in the way.
After replace a new battery my psp go going crazy. Charge only 1 or 2 min led going to green but not fully charge. Anyone can help me to fix this
Mus Mohamed - Reply Share
Cfw 6.61 pro update. Helppp
Thanks to this guide I was able to reseat the battery, the PSP was not turning on or charging any more, now everything is working again.
Marvin Arand - Reply Share
Past 24 Hours: 33
Past 7 Days: 116
Past 30 Days: 606
All Time: 109,644
