Up to 20% off select tools
PSP Go Back Cover Replacement
Views: 22K
View statistics:
Past 24 Hours:
3
Past 7 Days:
31
Past 30 Days:
137
All Time:
21,777
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows you how to remove the PSP Go's back cover.
    1. PSP Go Back Cover Replacement, Back Cover: step 1, image 1 of 2 PSP Go Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      Ask FixBot
    2. PSP Go Back Cover Replacement: step 2, image 1 of 2 PSP Go Back Cover Replacement: step 2, image 2 of 2
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      Ask FixBot
4 other people completed this guide.
Author
with
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 137
All Time: 21,777
