PSP Go Analog Joystick Replacement
Views: 25K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
174
All Time:
25,251
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to put a fresh analog joystick into the PSP Go!
Parts
Tools
    1. PSP Go Analog Joystick Replacement, Back Cover: step 1, image 1 of 2 PSP Go Analog Joystick Replacement, Back Cover: step 1, image 2 of 2
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      Ask FixBot
    2. PSP Go Analog Joystick Replacement: step 2, image 1 of 2 PSP Go Analog Joystick Replacement: step 2, image 2 of 2
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      Ask FixBot
    1. PSP Go Analog Joystick Replacement, Top Cover: step 3, image 1 of 1
      • Pull the top cover upwards gently from its housing.
      Ask FixBot
    1. PSP Go Analog Joystick Replacement, Bottom Plate: step 4, image 1 of 2 PSP Go Analog Joystick Replacement, Bottom Plate: step 4, image 2 of 2
      • Remove the two Phillips screws holding the bottom plate.
      • Gently lift the bottom plate away from the device.
      Ask FixBot
    1. PSP Go Analog Joystick Replacement, Analog Joystick: step 5, image 1 of 1
      • Use a #00 Phillips screwdriver to remove both screws holding the analog joystick in place.
      Ask FixBot
    2. PSP Go Analog Joystick Replacement: step 6, image 1 of 2 PSP Go Analog Joystick Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use a plastic opening tool to gently flip up the analog joystick's cable connector.
      • Use your fingers or tweezers to gently pull out the analog joystick cable from its connector.
      Ask FixBot
6 other people completed this guide.
1 Guide Comment
What about the plastic tab on the ribbon cable how do i attach the ribbon cable to the connector its very delicate
daniel - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 174
All Time: 25,251
