Up to 20% off select tools
PSP E1000 Battery Replacement
Views: 8.1K
View statistics:
Past 24 Hours:
24
Past 7 Days:
150
Past 30 Days:
625
All Time:
8,146
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
    1. PSP E1000 Battery Replacement, Battery: step 1, image 1 of 2 PSP E1000 Battery Replacement, Battery: step 1, image 2 of 2
      • To start the replacement flip the device over
      Ask FixBot
    2. PSP E1000 Battery Replacement: step 2, image 1 of 2 PSP E1000 Battery Replacement: step 2, image 2 of 2
      • We are going to start by removing the back panel.
      • To do this open the panel and gently squeeze in the UMD tray until it pops up.
      • It should lay flat against the back panel while open if done correctly
      Ask FixBot
    3. PSP E1000 Battery Replacement: step 3, image 1 of 2 PSP E1000 Battery Replacement: step 3, image 2 of 2
      • Gently bend the back panel to free the hinge on the left.
      • Once it is popped out it should look like the second photo
      Ask FixBot
      • The back panel can then be slid off
      Ask FixBot
    4. PSP E1000 Battery Replacement: step 5, image 1 of 3 PSP E1000 Battery Replacement: step 5, image 2 of 3 PSP E1000 Battery Replacement: step 5, image 3 of 3
      • Remove the screw with a #00 Philips and slide up the battery cover.
      • The battery can now be removed by pulling it out.
      • When reinstalling, it is useful to use a spudger to push the cable back in.
      • Congratulations you have replaced your PSP E1000's battery
      Ask FixBot
5 other people completed this guide.
Author
with
Caleb Pierce
1,344 Reputation
8 Guides authored
1 Guide Comment
Haleakala,akama
Micheal Churchill - Reply Share
Past 24 Hours: 24
Past 7 Days: 150
Past 30 Days: 625
All Time: 8,146
