PSP 300xc UMD Door Replacement
    1. PSP 300xc UMD Door Replacement, Battery: step 1, image 1 of 2 PSP 300xc UMD Door Replacement, Battery: step 1, image 2 of 2
      • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
      • Lift the battery out of the PSP.
      Ask FixBot
    1. PSP 300xc UMD Door Replacement, Front Case: step 2, image 1 of 1
      • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
      Ask FixBot
    2. PSP 300xc UMD Door Replacement: step 3, image 1 of 2 PSP 300xc UMD Door Replacement: step 3, image 2 of 2
      • Remove four Phillips screws from the back of the PSP.
      Ask FixBot
    3. PSP 300xc UMD Door Replacement: step 4, image 1 of 1
      • Remove two Phillips screws from the top of the PSP.
      Ask FixBot
    4. PSP 300xc UMD Door Replacement: step 5, image 1 of 1
      • Remove a single screw from the bottom edge of the PSP.
      Ask FixBot
    5. PSP 300xc UMD Door Replacement: step 6, image 1 of 2 PSP 300xc UMD Door Replacement: step 6, image 2 of 2
      • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
      Ask FixBot
    1. PSP 300xc UMD Door Replacement, LCD: step 7, image 1 of 1
      • Remove a single Phillips screw securing the home bar to the PSP 300xc.
      Ask FixBot
    2. PSP 300xc UMD Door Replacement: step 8, image 1 of 2 PSP 300xc UMD Door Replacement: step 8, image 2 of 2
      • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
      • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
      Ask FixBot
    3. PSP 300xc UMD Door Replacement: step 9, image 1 of 1
      • Insert a spudger under the LCD, beside the black plastic tab.
      • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
      Ask FixBot
    4. PSP 300xc UMD Door Replacement: step 10, image 1 of 1
      • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
      Ask FixBot
    5. PSP 300xc UMD Door Replacement: step 11, image 1 of 3 PSP 300xc UMD Door Replacement: step 11, image 2 of 3 PSP 300xc UMD Door Replacement: step 11, image 3 of 3
      • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
      • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
      • Home bar cable
      • Microphone cable
      • LCD display data cable
      • Touchscreen cable
      • Be sure you are prying up on the retaining flap, not the socket itself
      • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
      Ask FixBot
    6. PSP 300xc UMD Door Replacement: step 12, image 1 of 1
      • Remove the LCD from the PSP 300xc.
      Ask FixBot
    1. PSP 300xc UMD Door Replacement, Home Bar: step 13, image 1 of 3 PSP 300xc UMD Door Replacement, Home Bar: step 13, image 2 of 3 PSP 300xc UMD Door Replacement, Home Bar: step 13, image 3 of 3
      • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
      • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
      • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
      • The home bar should now lift out of the PSP 300xc.
      Ask FixBot
    1. PSP 300xc UMD Door Replacement, UMD Brace: step 14, image 1 of 1
      • Using the flat edge of a spudger, pry the power board away from the PSP 300xc.
      Ask FixBot
    2. PSP 300xc UMD Door Replacement: step 15, image 1 of 1
      • Lift the right silver rim up and off the PSP 300xc.
      Ask FixBot
    3. PSP 300xc UMD Door Replacement: step 16, image 1 of 1
      • Using the pointed end of a spudger, pull the UMD door spring to the left, and remove it from the PSP.
      Ask FixBot
    4. PSP 300xc UMD Door Replacement: step 17, image 1 of 3 PSP 300xc UMD Door Replacement: step 17, image 2 of 3 PSP 300xc UMD Door Replacement: step 17, image 3 of 3
      • Use your fingernail or the edge of a spudger to flip up the retaining flap on the UMD drive ribbon socket.
      • Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
      • Use a spudger to gently pull both ribbon cables straight out of their sockets.
      Ask FixBot
    5. PSP 300xc UMD Door Replacement: step 18, image 1 of 2 PSP 300xc UMD Door Replacement: step 18, image 2 of 2
      Tool used on this step:
      Buy
      • Flip the PSP 300xc over and open the UMD door.
      • Using a pair of tweezers, grab the small rubber square between the metal UMD brace and case, and lift it out of the PSP 300xc.
      • Repeat for the rubber square on the other side of the UMD door.
      Ask FixBot
    6. PSP 300xc UMD Door Replacement: step 19, image 1 of 3 PSP 300xc UMD Door Replacement: step 19, image 2 of 3 PSP 300xc UMD Door Replacement: step 19, image 3 of 3
      • Slide the UMD brace toward the top of the UMD door until the brace disconnects from the door. Remove the brace.
      Ask FixBot
    1. PSP 300xc UMD Door Replacement, UMD Door: step 20, image 1 of 2 PSP 300xc UMD Door Replacement, UMD Door: step 20, image 2 of 2
      • Bend the PSP 300xc case while pulling up on the right edge of the UMD door until the right edge lifts free.
      • Remove the UMD door.
      Ask FixBot
2 other people completed this guide.
Matthew Newsom
42,939 Reputation
67 Guides authored
1 Guide Comment
wow! I really found the steps very easy and well presented Matt. Great stuff!!! I even replaced my UMD door, and normally I mess up, but not this time! You saved me! thanks
ceejay - Reply Share
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 170
All Time: 16,258
