Up to 20% off select tools
PSP 300xc Power Switch Board Replacement
Views: 9.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
146
All Time:
9,923
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Has the power switch broken on your precious PSP 300xc? Replace the power switch board, and set everything right once more.
    1. PSP 300xc Power Switch Board Replacement, Battery: step 1, image 1 of 2 PSP 300xc Power Switch Board Replacement, Battery: step 1, image 2 of 2
      • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
      • Lift the battery out of the PSP.
      Ask FixBot
    1. PSP 300xc Power Switch Board Replacement, Front Case: step 2, image 1 of 1
      • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
      Ask FixBot
    2. PSP 300xc Power Switch Board Replacement: step 3, image 1 of 2 PSP 300xc Power Switch Board Replacement: step 3, image 2 of 2
      • Remove four Phillips screws from the back of the PSP.
      Ask FixBot
    3. PSP 300xc Power Switch Board Replacement: step 4, image 1 of 1
      • Remove two Phillips screws from the top of the PSP.
      Ask FixBot
    4. PSP 300xc Power Switch Board Replacement: step 5, image 1 of 1
      • Remove a single screw from the bottom edge of the PSP.
      Ask FixBot
    5. PSP 300xc Power Switch Board Replacement: step 6, image 1 of 2 PSP 300xc Power Switch Board Replacement: step 6, image 2 of 2
      • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
      Ask FixBot
    1. PSP 300xc Power Switch Board Replacement, LCD: step 7, image 1 of 1
      • Remove a single Phillips screw securing the home bar to the PSP 300xc.
      Ask FixBot
    2. PSP 300xc Power Switch Board Replacement: step 8, image 1 of 2 PSP 300xc Power Switch Board Replacement: step 8, image 2 of 2
      • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
      • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
      Ask FixBot
    3. PSP 300xc Power Switch Board Replacement: step 9, image 1 of 1
      • Insert a spudger under the LCD, beside the black plastic tab.
      • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
      Ask FixBot
    4. PSP 300xc Power Switch Board Replacement: step 10, image 1 of 1
      • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
      Ask FixBot
    5. PSP 300xc Power Switch Board Replacement: step 11, image 1 of 3 PSP 300xc Power Switch Board Replacement: step 11, image 2 of 3 PSP 300xc Power Switch Board Replacement: step 11, image 3 of 3
      • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
      • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
      • Home bar cable
      • Microphone cable
      • LCD display data cable
      • Touchscreen cable
      • Be sure you are prying up on the retaining flap, not the socket itself
      • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
      Ask FixBot
    6. PSP 300xc Power Switch Board Replacement: step 12, image 1 of 1
      • Remove the LCD from the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Power Switch Board Replacement, Home Bar: step 13, image 1 of 3 PSP 300xc Power Switch Board Replacement, Home Bar: step 13, image 2 of 3 PSP 300xc Power Switch Board Replacement, Home Bar: step 13, image 3 of 3
      • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
      • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
      • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
      • The home bar should now lift out of the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Power Switch Board Replacement, Trigger Buttons: step 14, image 1 of 2 PSP 300xc Power Switch Board Replacement, Trigger Buttons: step 14, image 2 of 2
      • Remove both trigger buttons by lifting them off the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Power Switch Board Replacement, Power Switch Board: step 15, image 1 of 1
      • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
      • Pull the ribbon cable out of its socket.
      Ask FixBot
    2. PSP 300xc Power Switch Board Replacement: step 16, image 1 of 1
      • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
      • Remove the power switch board from the PSP.
      Ask FixBot
Author
with
Matthew Newsom
43,302 Reputation
67 Guides authored
1 Guide Comment
Hello, author. I would like to ask if it's possible to skip from step 6 to step 16, as I don't need to replace the power switch. I only need to replace the side frame. I just need to be able to lift it slightly so that I can replace the frame
王二孬 - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 146
All Time: 9,923
