Up to 20% off select tools
PSP 300xc Motherboard Replacement
Views: 13K
View statistics:
Past 24 Hours:
11
Past 7 Days:
47
Past 30 Days:
211
All Time:
13,089
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Something unmentionably horrible has happened to your PSp 300xc. The motherboard is fried for one reason or another, but have no fear! This guide allows you to replace the dead board with a brand new one!
    1. PSP 300xc Motherboard Replacement, Battery: step 1, image 1 of 2 PSP 300xc Motherboard Replacement, Battery: step 1, image 2 of 2
      • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
      • Lift the battery out of the PSP.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Front Case: step 2, image 1 of 1
      • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
      Ask FixBot
    2. PSP 300xc Motherboard Replacement: step 3, image 1 of 2 PSP 300xc Motherboard Replacement: step 3, image 2 of 2
      • Remove four Phillips screws from the back of the PSP.
      Ask FixBot
    3. PSP 300xc Motherboard Replacement: step 4, image 1 of 1
      • Remove two Phillips screws from the top of the PSP.
      Ask FixBot
    4. PSP 300xc Motherboard Replacement: step 5, image 1 of 1
      • Remove a single screw from the bottom edge of the PSP.
      Ask FixBot
    5. PSP 300xc Motherboard Replacement: step 6, image 1 of 2 PSP 300xc Motherboard Replacement: step 6, image 2 of 2
      • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, LCD: step 7, image 1 of 1
      • Remove a single Phillips screw securing the home bar to the PSP 300xc.
      Ask FixBot
    2. PSP 300xc Motherboard Replacement: step 8, image 1 of 2 PSP 300xc Motherboard Replacement: step 8, image 2 of 2
      • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
      • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
      Ask FixBot
    3. PSP 300xc Motherboard Replacement: step 9, image 1 of 1
      • Insert a spudger under the LCD, beside the black plastic tab.
      • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
      Ask FixBot
    4. PSP 300xc Motherboard Replacement: step 10, image 1 of 1
      • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
      Ask FixBot
    5. PSP 300xc Motherboard Replacement: step 11, image 1 of 3 PSP 300xc Motherboard Replacement: step 11, image 2 of 3 PSP 300xc Motherboard Replacement: step 11, image 3 of 3
      • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
      • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
      • Home bar cable
      • Microphone cable
      • LCD display data cable
      • Touchscreen cable
      • Be sure you are prying up on the retaining flap, not the socket itself
      • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
      Ask FixBot
    6. PSP 300xc Motherboard Replacement: step 12, image 1 of 1
      • Remove the LCD from the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Home Bar: step 13, image 1 of 3 PSP 300xc Motherboard Replacement, Home Bar: step 13, image 2 of 3 PSP 300xc Motherboard Replacement, Home Bar: step 13, image 3 of 3
      • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
      • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
      • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
      • The home bar should now lift out of the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Trigger Buttons: step 14, image 1 of 2 PSP 300xc Motherboard Replacement, Trigger Buttons: step 14, image 2 of 2
      • Remove both trigger buttons by lifting them off the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Power Switch Board: step 15, image 1 of 1
      • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
      • Pull the ribbon cable out of its socket.
      Ask FixBot
    2. PSP 300xc Motherboard Replacement: step 16, image 1 of 1
      • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
      • Remove the power switch board from the PSP.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Power Jack: step 17, image 1 of 1
      • Remove a single Phillips screw securing the power jack to the PSP.
      Ask FixBot
    2. PSP 300xc Motherboard Replacement: step 18, image 1 of 1
      • Using the flat edge of a spudger, pry the small black tab away from the power jack to free it from the case.
      Ask FixBot
    3. PSP 300xc Motherboard Replacement: step 19, image 1 of 1
      • Disconnect the power jack from its connector on the motherboard by pulling it straight out of its socket.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Analog Stick: step 20, image 1 of 1
      • Using the flat end of a spudger, peel the 'L' trigger contact pad up from the case.
      Ask FixBot
    2. PSP 300xc Motherboard Replacement: step 21, image 1 of 2 PSP 300xc Motherboard Replacement: step 21, image 2 of 2
      • Using a fingernail or spudger, flip up the retaining flap on the d-pad and 'L' trigger ribbon cable.
      • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
      Ask FixBot
    3. PSP 300xc Motherboard Replacement: step 22, image 1 of 1
      • Remove a single Phillips screw securing the analog stick to the PSP 300xc.
      Ask FixBot
    4. PSP 300xc Motherboard Replacement: step 23, image 1 of 2 PSP 300xc Motherboard Replacement: step 23, image 2 of 2
      • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the analog stick ribbon connector.
      • Lift the analog stick out of the PSP 300xc, disconnecting the ribbon cable as you remove it.
      Ask FixBot
    1. PSP 300xc Motherboard Replacement, Motherboard: step 24, image 1 of 1
      • Push the small black tab holding the right speaker to the left.
      • The speaker will pop out of place.
      Ask FixBot
    2. PSP 300xc Motherboard Replacement: step 25, image 1 of 1
      • Using the flat edge of a spudger, pry the wireless board cable connector straight up and off the motherboard.
      Ask FixBot
    3. PSP 300xc Motherboard Replacement: step 26, image 1 of 3 PSP 300xc Motherboard Replacement: step 26, image 2 of 3 PSP 300xc Motherboard Replacement: step 26, image 3 of 3
      • Using a fingernail or spudger, flip up the retaining flap on the following three ZIF connectors.
      • Action button contact pad ribbon
      • UMD drive ribbon
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
      • Use your fingers or a spudger to gently pull all three ribbon cables straight out of their sockets.
      Ask FixBot
    4. PSP 300xc Motherboard Replacement: step 27, image 1 of 2 PSP 300xc Motherboard Replacement: step 27, image 2 of 2
      • Lift the right silver rim up and off the PSP 300xc
      • Lift the left silver rim up and off the PSP 300xc
      Ask FixBot
    5. PSP 300xc Motherboard Replacement: step 28, image 1 of 2 PSP 300xc Motherboard Replacement: step 28, image 2 of 2
      • Lift the motherboard up from its bottom edge about 45 degrees from the case.
      • Slowly attempt to pull the motherboard out at roughly a 45 degree angle from the case.
      • It takes a little fidgeting to get the motherboard to come apart from the case.
      Ask FixBot
16 other people completed this guide.
Author
with
Matthew Newsom
43,302 Reputation
67 Guides authored
3 Guide Comments
looking for bottom stick board
louie khalil - Reply Share
part No. 0402071
buttons is not working the right side
Past 24 Hours: 11
Past 7 Days: 47
Past 30 Days: 211
All Time: 13,089
