Up to 20% off select tools
PSP 300xc Home Bar Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
9
Past 7 Days:
37
Past 30 Days:
147
All Time:
6,537
Comments: 3
3 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Are your home bar buttons no longer working? Replace the home bar button strip to make it good as new.
    1. PSP 300xc Home Bar Replacement, Battery: step 1, image 1 of 2 PSP 300xc Home Bar Replacement, Battery: step 1, image 2 of 2
      • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
      • Lift the battery out of the PSP.
      Ask FixBot
    1. PSP 300xc Home Bar Replacement, Front Case: step 2, image 1 of 1
      • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
      Ask FixBot
    2. PSP 300xc Home Bar Replacement: step 3, image 1 of 2 PSP 300xc Home Bar Replacement: step 3, image 2 of 2
      • Remove four Phillips screws from the back of the PSP.
      Ask FixBot
    3. PSP 300xc Home Bar Replacement: step 4, image 1 of 1
      • Remove two Phillips screws from the top of the PSP.
      Ask FixBot
    4. PSP 300xc Home Bar Replacement: step 5, image 1 of 1
      • Remove a single screw from the bottom edge of the PSP.
      Ask FixBot
    5. PSP 300xc Home Bar Replacement: step 6, image 1 of 2 PSP 300xc Home Bar Replacement: step 6, image 2 of 2
      • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
      Ask FixBot
    1. PSP 300xc Home Bar Replacement, LCD: step 7, image 1 of 1
      • Remove a single Phillips screw securing the home bar to the PSP 300xc.
      Ask FixBot
    2. PSP 300xc Home Bar Replacement: step 8, image 1 of 2 PSP 300xc Home Bar Replacement: step 8, image 2 of 2
      • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
      • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
      Ask FixBot
    3. PSP 300xc Home Bar Replacement: step 9, image 1 of 1
      • Insert a spudger under the LCD, beside the black plastic tab.
      • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
      Ask FixBot
    4. PSP 300xc Home Bar Replacement: step 10, image 1 of 1
      • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
      Ask FixBot
    5. PSP 300xc Home Bar Replacement: step 11, image 1 of 3 PSP 300xc Home Bar Replacement: step 11, image 2 of 3 PSP 300xc Home Bar Replacement: step 11, image 3 of 3
      • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
      • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
      • Home bar cable
      • Microphone cable
      • LCD display data cable
      • Touchscreen cable
      • Be sure you are prying up on the retaining flap, not the socket itself
      • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
      Ask FixBot
    6. PSP 300xc Home Bar Replacement: step 12, image 1 of 1
      • Remove the LCD from the PSP 300xc.
      Ask FixBot
    1. PSP 300xc Home Bar Replacement, Home Bar: step 13, image 1 of 3 PSP 300xc Home Bar Replacement, Home Bar: step 13, image 2 of 3 PSP 300xc Home Bar Replacement, Home Bar: step 13, image 3 of 3
      • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
      • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
      • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
      • The home bar should now lift out of the PSP 300xc.
      Ask FixBot
2 other people completed this guide.
Author
with
Matthew Newsom
43,302 Reputation
67 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 37
Past 30 Days: 147
All Time: 6,537
