Up to 20% off select tools
PSP 300x UMD Drive Replacement
Views: 75K
View statistics:
Past 24 Hours:
28
Past 7 Days:
176
Past 30 Days:
997
All Time:
75,348
Comments: 21
14 comments on steps, 7 guide comments.
Go to guide comments
Completed: 31
31 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Student In Progress
This guide is being worked on by hardworking students.
Parts
Tools
Introduction
Go to step 1 ↓
Guide for removing the UMD Drive of a Sony PSP-3000
    1. PSP 300x UMD Drive Replacement, Battery: step 1, image 1 of 3 PSP 300x UMD Drive Replacement, Battery: step 1, image 2 of 3 PSP 300x UMD Drive Replacement, Battery: step 1, image 3 of 3
      • Place the PSP face down and locate the battery cover on the left side of the device.
      • Lift and remove the battery cover to reveal the battery.
      • Remove the battery.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, Front Casing: step 2, image 1 of 1
      • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 3, image 1 of 2 PSP 300x UMD Drive Replacement: step 3, image 2 of 2
      • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
      • Two are located behind the battery's warranty sticker.
      • Two are located on the right side of the PSP.
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 4, image 1 of 1
      • Next, unscrew the two screws located at the top of the PSP.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 5, image 1 of 1
      • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
      Ask FixBot
    5. PSP 300x UMD Drive Replacement: step 6, image 1 of 2 PSP 300x UMD Drive Replacement: step 6, image 2 of 2
      • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
      • Remove the front casing completely.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, LCD Screen: step 7, image 1 of 2 PSP 300x UMD Drive Replacement, LCD Screen: step 7, image 2 of 2
      • Push the homebar to the right to release the tab located on the right side of the LCD screen.
      • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 8, image 1 of 3 PSP 300x UMD Drive Replacement: step 8, image 2 of 3 PSP 300x UMD Drive Replacement: step 8, image 3 of 3
      • Slowly lift the LCD screen off the PSP starting at the top edge corner.
      • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
      • Orientation of PSP is flipped in photo.
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 9, image 1 of 2 PSP 300x UMD Drive Replacement: step 9, image 2 of 2
      • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
      • Pull all four ribbon cables out.
      • Now remove the LCD screen and homebar from the PSP.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 10, image 1 of 1
      • Remove the metal tab that lies above the LCD screen.
      • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, Trigger Buttons: step 11, image 1 of 1
      • Remove the screw securing 'L' trigger to the PSP.
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 12, image 1 of 1
      • Remove the white plastic piece that holds the 'L' trigger in place.
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 13, image 1 of 1
      • Remove the 'L' trigger from the PSP.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 14, image 1 of 1
      • Remove the screw securing the 'R' trigger.
      Ask FixBot
    5. PSP 300x UMD Drive Replacement: step 15, image 1 of 1
      • Remove the white plastic piece that holds the 'R' trigger in place.
      Ask FixBot
    6. PSP 300x UMD Drive Replacement: step 16, image 1 of 1
      • Remove the 'R' trigger from the PSP.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, Analog Stick: step 17, image 1 of 1
      • Remove the screw from the bottom left edge of the PSP.
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 18, image 1 of 1
      • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 19, image 1 of 2 PSP 300x UMD Drive Replacement: step 19, image 2 of 2
      • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
      • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 20, image 1 of 1
      • Remove the cable from the connector and remove the entire black piece from the PSP.
      Ask FixBot
    5. PSP 300x UMD Drive Replacement: step 21, image 1 of 1
      • Remove the screw holding the analog stick in place.
      Ask FixBot
    6. PSP 300x UMD Drive Replacement: step 22, image 1 of 2 PSP 300x UMD Drive Replacement: step 22, image 2 of 2
      • Flip up the lock on the analog sticks ribbon cable.
      • Remove the analog stick from the PSP.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, Power Jack: step 23, image 1 of 1
      • Flip up the lock and detach the ribbon cable above the power jack.
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 24, image 1 of 1
      • Remove the screw from the power jack.
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 25, image 1 of 1
      • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 26, image 1 of 1
      • Pull the plug connecting the power jack to the motherboard.
      • Remove the power jack.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, Speaker: step 27, image 1 of 2 PSP 300x UMD Drive Replacement, Speaker: step 27, image 2 of 2
      • Push the black tab at the bottom of the speaker to pop the speaker out of place, and remove the speaker.
      • The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
      • Make sure the new/replacement speaker does not spring out during reassembly.
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, Motherboard: step 28, image 1 of 1
      • Remove the cable carefully by lifting upwards from port attached to the motherboard .
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 29, image 1 of 1
      • Flip up both of the locks and remove both cables as shown
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 30, image 1 of 1
      • Flip up the lock and remove the ribbon cable located at the bottom edge of the PSP.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 31, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the bottom left screw attached to the PSP
      Ask FixBot
    5. PSP 300x UMD Drive Replacement, Remove Power Switch Panel: step 32, image 1 of 3 PSP 300x UMD Drive Replacement, Remove Power Switch Panel: step 32, image 2 of 3 PSP 300x UMD Drive Replacement, Remove Power Switch Panel: step 32, image 3 of 3
      • Remove the screw located at the top of the power switch panel.
      • Gently lift and remove the panel from the switch side
      Ask FixBot
    6. PSP 300x UMD Drive Replacement: step 33, image 1 of 1
      • Remove the silver rim on the right side of the PSP.
      Ask FixBot
    7. PSP 300x UMD Drive Replacement: step 34, image 1 of 1
      • Remove the silver rim on the left side of the PSP.
      Ask FixBot
    8. PSP 300x UMD Drive Replacement: step 35, image 1 of 2 PSP 300x UMD Drive Replacement: step 35, image 2 of 2
      • Remove the motherboard from the PSP
      Ask FixBot
    1. PSP 300x UMD Drive Replacement, UMD Drive: step 36, image 1 of 1
      • On the bottom of the back of the PSP, pull the white plastic piece out.
      Ask FixBot
    2. PSP 300x UMD Drive Replacement: step 37, image 1 of 1
      • Use a spudger and pull the spring out and remove it from the PSP.
      Ask FixBot
    3. PSP 300x UMD Drive Replacement: step 38, image 1 of 2 PSP 300x UMD Drive Replacement: step 38, image 2 of 2
      Tool used on this step:
      Buy
      • Open the UMD (disk drive) and locate the two small black rubber squares wedged in the space between the casing and the metal drive hinge on either side.
      • Pull these out using a pair of tweezers.
      Ask FixBot
    4. PSP 300x UMD Drive Replacement: step 39, image 1 of 1
      • Detach the metal piece from where it is attached to the body underneath the rubber pieces that were just removed.
      • The side of the piece that is closest to the door opening should now be loose. The whole piece should now be slid farther into the drive through the slots.
      • Once you slide the piece toward the back of the slots, the side that is still attached can be pried towards the center of the drive on each side to remove it from the slots on the door.
      Ask FixBot
    5. PSP 300x UMD Drive Replacement: step 40, image 1 of 1
      • Grabbing the PSP with both hands, gently pinch the UMD lid towards the right side (the side without the battery).
      • Pull up and the the left side carefully to remove the lid from the PSP. (The casing may have to flex a little bit to allow this)
      Ask FixBot
    6. PSP 300x UMD Drive Replacement: step 41, image 1 of 1
      • Remove the four screw from the UMD drive.
      Ask FixBot
    7. PSP 300x UMD Drive Replacement: step 42, image 1 of 1
      • Remove the UMD Drive.
      Ask FixBot
31 other people completed this guide.
Author
with
mbnewsom
3,581 Reputation
11 Guides authored
7 Guide Comments
Perfect!!! You forgot to mention 'GET YOUR EYEGLASSES' for the 50+ year old fathers that have to help on this procedure!!!! Man, oh man, are those parts small and delicate!!!! GREAT tutorial, than you very much! Blind in Boston.
Rosebud Mosaics - Reply Share
The tutorial was great btw, however after assembling everything into my new blue Mod i was left with a white plastic piece and a spring witch is in my psp 3001 models , not sure but i see in the last picture of this tutorial you have the white piece left in the drive. it is located behind the cd rom part near the top of the psp where the 2 x holes are. it sucks cause it dont close properly without the white piece and theres also 1 of the 2 springs not mentioned in this tutorial neither im trying to figure out where it goes. But thanks for this guide as it has helped me alot..
Ken
Kenneth A - Reply Share
Someone found the location of the missing spring? Haven’t figured it out yet…
tanja-stephan - Reply Share
This has too many extra steps. If you’re *just* taking out the UMD drive, you only need to follow these sections: battery, casing, LCD screen, UMD drive. This guide should really just be called “how to completely disassemble your PSP 3000”.
Christopher Dickinson - Reply Share
What about removing the UMD trigger? I didn’t see it anywhere in this tutorial. Please help.
C Rad - Reply Share
Past 24 Hours: 28
Past 7 Days: 176
Past 30 Days: 997
All Time: 75,348
