PSP 300x Power Board Replacement
Views: 25K
View statistics:
Past 24 Hours:
6
Past 7 Days:
50
Past 30 Days:
253
All Time:
24,958
Comments: 13
11 comments on steps, 2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
If your 3000-series PSP is having issues not turning on, this guide will explain how to replace the circuit board for the power switch.
When the power circuit board functions properly, the light next to the power switch should be illuminated after the PSP is turned on, even if there is no audio or video. A faulty circuit board can prevent the device from drawing power and beginning the startup sequence
PSP batteries have had reported issues with swelling, so remember to visually inspect the battery cover for bulging before removing the battery. For more information on swollen batteries, click here.
Before getting started with this guide, ensure that the problem is actually the circuit board itself. Follow this guide up to Step 10 to disassemble the PSP, and inspect the switch to make sure the power button on the case activates the switch on the circuit. With the screen removed, also ensure that the silver ribbon cable has a firm connection both on the power board and on the motherboard. If the cables are loose, then they can be secured with electrical tape underneath the cable and away from the connectors.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. PSP 300x Power Board Replacement, Battery: step 1, image 1 of 3 PSP 300x Power Board Replacement, Battery: step 1, image 2 of 3 PSP 300x Power Board Replacement, Battery: step 1, image 3 of 3
      • Place the PSP face down and locate the battery cover on the left side of the device.
      • Lift and remove the battery cover to reveal the battery.
      • Remove the battery.
      Ask FixBot
    1. PSP 300x Power Board Replacement, Front Casing: step 2, image 1 of 1
      • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
      Ask FixBot
    2. PSP 300x Power Board Replacement: step 3, image 1 of 2 PSP 300x Power Board Replacement: step 3, image 2 of 2
      • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
      • Two are located behind the battery's warranty sticker.
      • Two are located on the right side of the PSP.
      Ask FixBot
    3. PSP 300x Power Board Replacement: step 4, image 1 of 1
      • Next, unscrew the two screws located at the top of the PSP.
      Ask FixBot
    4. PSP 300x Power Board Replacement: step 5, image 1 of 1
      • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
      Ask FixBot
    5. PSP 300x Power Board Replacement: step 6, image 1 of 2 PSP 300x Power Board Replacement: step 6, image 2 of 2
      • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
      • Remove the front casing completely.
      Ask FixBot
    1. PSP 300x Power Board Replacement, LCD Screen: step 7, image 1 of 2 PSP 300x Power Board Replacement, LCD Screen: step 7, image 2 of 2
      • Push the homebar to the right to release the tab located on the right side of the LCD screen.
      • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
      Ask FixBot
    2. PSP 300x Power Board Replacement: step 8, image 1 of 3 PSP 300x Power Board Replacement: step 8, image 2 of 3 PSP 300x Power Board Replacement: step 8, image 3 of 3
      • Slowly lift the LCD screen off the PSP starting at the top edge corner.
      • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
      • Orientation of PSP is flipped in photo.
      Ask FixBot
    3. PSP 300x Power Board Replacement: step 9, image 1 of 2 PSP 300x Power Board Replacement: step 9, image 2 of 2
      • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
      • Pull all four ribbon cables out.
      • Now remove the LCD screen and homebar from the PSP.
      Ask FixBot
    4. PSP 300x Power Board Replacement: step 10, image 1 of 1
      • Remove the metal tab that lies above the LCD screen.
      • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
      Ask FixBot
    1. PSP 300x Power Board Replacement, Power Board: step 11, image 1 of 1
      • Using a spudger, lift up the lock and remove the ribbon cable from the motherboard
      Ask FixBot
    2. PSP 300x Power Board Replacement: step 12, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the screw located on the power switch board.
      Ask FixBot
    3. PSP 300x Power Board Replacement: step 13, image 1 of 1
      • Lift up and remove the power-switch board.
      Ask FixBot
Finish Line
8 other people completed this guide.
mbnewsom
3,551 Reputation
11 Guides authored
2 Guide Comments
for power board you can skip 7-10 steps ,1 to 6 is remove front case , real work start at step 11 ,between those was taking apart sreen, but not need for power board replacement.
javi - Reply Share
HS : The website sell Battery for 300x but where are the AC Block and the Yellow round male plug ?
Fine Mouche - Reply Share
Past 24 Hours: 6
Past 7 Days: 50
Past 30 Days: 253
All Time: 24,958
