PSP 300x D-Pad Replacement
Views: 14K
View statistics:
Past 24 Hours:
9
Past 7 Days:
49
Past 30 Days:
254
All Time:
14,052
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
Steps for replacing malfunctioned directional pads in a Sony PSP-3000
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. PSP 300x D-Pad Replacement, Battery: step 1, image 1 of 3 PSP 300x D-Pad Replacement, Battery: step 1, image 2 of 3 PSP 300x D-Pad Replacement, Battery: step 1, image 3 of 3
      • Place the PSP face down and locate the battery cover on the left side of the device.
      • Lift and remove the battery cover to reveal the battery.
      • Remove the battery.
      Ask FixBot
    1. PSP 300x D-Pad Replacement, Front Casing: step 2, image 1 of 1
      • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
      Ask FixBot
    2. PSP 300x D-Pad Replacement: step 3, image 1 of 2 PSP 300x D-Pad Replacement: step 3, image 2 of 2
      • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
      • Two are located behind the battery's warranty sticker.
      • Two are located on the right side of the PSP.
      Ask FixBot
    3. PSP 300x D-Pad Replacement: step 4, image 1 of 1
      • Next, unscrew the two screws located at the top of the PSP.
      Ask FixBot
    4. PSP 300x D-Pad Replacement: step 5, image 1 of 1
      • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
      Ask FixBot
    5. PSP 300x D-Pad Replacement: step 6, image 1 of 2 PSP 300x D-Pad Replacement: step 6, image 2 of 2
      • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
      • Remove the front casing completely.
      Ask FixBot
    1. PSP 300x D-Pad Replacement, D-Pad: step 7, image 1 of 2 PSP 300x D-Pad Replacement, D-Pad: step 7, image 2 of 2
      • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
      • Remove the D-pad and the rubber piece.
      Ask FixBot
5 other people completed this guide.
mbnewsom
3,551 Reputation
11 Guides authored
1 Guide Comment
Is it for 2000?
Kaio Igor - Reply Share
Past 24 Hours: 9
Past 7 Days: 49
Past 30 Days: 254
All Time: 14,052
